Question about Sharp CD-C444 Shelf System
My CD-C444 worked just fine listening to music on f.m radio and now there is no sound at all' can someone please help me
No sound out of the pioneer vsx-1121-k
Try removing all the speaker and the HDMI connections; then use a headphone to listen to music from the tuner or a CD in stereo mode. Better in direct mode. If you hear your music correctly the receiver could be working correctly. If no music is heard, you may need to have it repaired professionally.
If you can hear music, connect the main FL & FR speakers and verify you can hear music that way, without the headphone connected.
If you can hear music that way, connect the center and rears. Try a mode that uses all channels to verify all sound channels are working.
Then, and only then start adding your HDMI connections.
Good luck
Jan 19, 2015 | Pioneer Vsx-1121-k 7.1 Home Theater...
I have burned cd and my sharp cd-c444 wont play it. why
Check what format you burned the songs from. Some formats, like MP3, mpg, among others will not play on all stereo systems. When you burn the songs, make sure that MP3 is not the format for the Sharp system, and that in fact, mpg is. I hope that solves your problem.
Sep 27, 2010 | Sharp CD-C444 Shelf System
Cd player keeps showing nd cannot play any type of Cd at all
Hi Tony,
Your GE 7-5295 keeps showing nd (no disc), this simply means that your lens has been damaged. Please replace the lens and you would enjoy listening to music once again in your kitchen.
Kind Regards
May 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
Location of reset on unit
when you disconnect it from cables, it resets. But i believe that is not the problem. Check speaker cables. I think you have problem with internal power amps. They have thermal and current protection. look for short circuits on speakers or speaker cables.
May 30, 2009 | Sony CDX-GT500 CD Player
Subwoofer does not turn on when playin usb or cd or aux
I have the same problem..Have you guys sorted it yet?
Mar 12, 2009 | Car Audio & Video
Cd player
Try turning your cd disc over, it may be installed upside down!
Jan 06, 2009 | 2001 BMW 5 Series
No sound!!!!!
sounds like you blew an interior speaker.. it would cause the radios internal amp to shut down.
Jan 17, 2008 | Panasonic CQ-C8303U CD Player
Music Won't Play
ok I had this happen before
Try unplugging the possitvive battery from your car let sit for 5min or open the doors and turn the key making sure that your car is completly dead. then put the possitive wire back on.
this will reset the deck and make sure you also have the setting s correct I thin it called I tunes is set to on in the menu opptions
May 01, 2007 | Alpine CDA-9855 CD Player
32 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
