Question about Ridgid Ms1065lza Saw 10-inch Compound Miter With Laser
Pull trigger and nothing happens
When the trigger is pulled nothing happens, electric motor does not engage
    Problem Solver:
  • 15 Answers
Are you sure you have the safety key attached. Make sure power is on at receptacle.
Posted on Nov 29, 2014
I have a cub cadet rzt50 2006model, when I pull the PTO switch to engage the PTO nothing happens
check to see if you have voltage to pto if do bad pto replace it if not check the fuse then the switch
Aug 26, 2014 | Garden
Where is the PTO switch?
The switch is on the dash bezel, the electric clutch is on the deck. Some clutches can be adjusted but I need the model number of your mower first.
Jul 06, 2014 | Craftsman 24 Hp 48" Deck Yard Tractor
My chainsaw wont start. electric souce is good, but nothing happens when you press the trigger.
Check the chainbrake is fully pulled back to the top handle, many electric saws have a micro switch to prevent the saw from running with the brake on.
Jul 16, 2011 | Mcculloch 16" Electric Chain Saw Mcc3516f
After sitting for several weeks, I plugged my electric 1500 PSI unit and nothing happened. Usually there is a pulse in the motor and it waits for the trigger to flow water to reinitialize the pump. ...
this Karcher unit have a termal overload in the motor but your problem can be cause by a pressure switch the shutt on and off the motor when you stop spraying.
Aug 15, 2010 | Karcher K2.26 Electric Power Washer
D25600 does nothing when i pull the trigger
take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Jul 05, 2010 | Dewalt D25600K Electric Rotary Hammer
Electric chain saw has not been used in quite some time and when I plugged it in and pulled the trigger, nothing happened.
with the eaw unplugged, try pulling the chain by hand to turn the motor to a different spot on the armature.
Jan 26, 2010 | Garden
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
The blades wont engage when the button is pulled to start them.
If the mower drive belt is extremely loose the spring that holds it tight may have broken,check to see if it is broken before you replace the belt
Aug 18, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Wont start
try and change the solenoid!!
May 23, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Ridgid Ms1065lza Saw 10-inch Compound Miter With Laser Logo
102 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
