My mother-in-law's TV, which is not very old, has a problem with the picture. On the top 3 or 4 inches of the set there are always a series of horizontal lines. Is there a way to adjust this? or is the picture going bad??
Neither adjustable nor the picture going bad.
But appears to be a minor problem, chances are that a component in the vertical section of the TV is starting to fail. If you would opt to check it out/fix yourself, most probably would be a capacitor very near the vertical IC, value would be something like 100uF/50V. Though considered a simple job, this would require that you be familiar with electronic components & circuitry, a bit of soldering and use of a DVM.
Should you not be comfortable doing the above, perhaps your best bet would be to seek the services of a qualified tech.
Hope this be of some help/idea. Post back how things turned up or should you need additional information.
Good luck and kind regards.
You were right on!! We will spend $72 for a vertical grid capacitator, as you expected, rather than buying a new TV!!
Thanks!!
