Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet e2 f5 error
Washer wont start
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
  • 63 Answers
SOURCE: Whirlpool Duet Sport Washer won't start, Error code F-01
your main control board is bad,easy to replace //jc//
Posted on Jan 20, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 107 Answers
SOURCE: My Whirlpool duet washer is not draining. I am
If you hear the pump running and not draining, then take the toe panel off. Should be 3 1/4" screws on bottom. Remove the "coin catch". It looks like a BIG screw and it's white. Turn counterclockwise. There may be a sock, change ect...clogging it up. Dump it out and run machine. Have towel or bucket ready when removing coin catch.
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
What does it mean when washing machine has F5 and E2 error
If it is a Whirlpool then The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction in the lid lock area.
Please check the lid lock area and remove any objects in that area. Also verify there are no clothing items in the way.
Otherwise, provide the manufacturer name.
You may visit http://producthelp.whirlpool.com/Troubleshooting_Guides/Troubleshooting_for_Top_Load_HE_Washers_(Electronic_Control)/Error_Codes/F%23_E%23_or_F%23%23/F5_E2_Error_code_for_top_load_washers
Feb 04, 2017 | Washing Machines
I get a f5 e2 code on my whirlpool self cleaning oven
F5 E2 lid lock alert? The F5 E2 alert indicates the washer can't engage the lid lock because there may be an obstruction
Nov 05, 2016 | Whirlpool Ovens
Whirlpool duet washer wont start the wash button is flashing
We are sorry there is an issue with the washer, we invite you to contact us directly at Whirlpool Customer Service at 1-800-253-1301, so we can look into this issue further.
Aug 08, 2016 | Whirlpool Washing Machines
It stops it beeps it flashes F5 it's a whirlpool duet front load washer
When this happens press and hold any key down for one minute to clear f5 code
Apr 12, 2014 | Whirlpool Duet GHW9150P Front Load Washer
I had whirlpool duet wfw94hex0 error code f6 -e2
If it's the same as a UK version, F6 is a motor speed sense fault
Dec 23, 2012 | Whirlpool Duet GHW9150P Front Load Washer
I Have a whirlpool sport ht a number F5 came one what does this mean
The "F5" error means that the temperature sensor has recorded an unusual reading while using hot water. This usually is a sensor error rather than a malfunction of your hot water heater.
Check the temperature sensor connection. The sensor may be moved out of place or disconnected. Remove it from the plug and plug it back in to reset the connection. If the error appears again, replace the sensor on the washer.
Nov 20, 2012 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool washer f3 e2 code
your main control board is having a problem need to have service rereplace it free of charge and the board has been upgraded
Sep 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washer display code F05 what is this code?
the f5 error code is to do with the water inlet valve not working it will need replacing in the mean time try connecting the cold water to the hot select hot wash and see if the water flows into the machine
Dec 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
Whirlpool accubake oven error code
It may just be a door switch
Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool Duet GHW9150P Front Load Washer Logo
20 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
