Question about Pegasus Technologies Home
Pegasus shower valve leaks
Started leaking from the valve and will not easily adjust temps.
  • 44 Answers
SOURCE: leaky posi temp shower valve
coming from the uk it sounds that when you mention it leaks at night its a possibility thats when the water pressure increases & the valve starts to drip?
i know its not a solution but it may help you understand why its dripping at night.
Also the seals might be damaged in which case thats why its dripping check them for damage. make sure when you put the new cartridge in that you put some silicone grease around the seals as this helps the insertion & helps protect the seals from damage.
Kindly
Richie
Posted on Dec 15, 2008
  • 44 Answers
SOURCE: Grohe shower assembly leaking
hiit sounds as though the diverter valve is sticking in the mid position although you have turned it to the floor spout as you call it!!
Also it sounds as though the seals are possibly leaking causing the plasterboard (drywall) to get we, or possibly a joint may be leaking. Advice access the pip-work valve etc run shower & check with torch (flashlight) to see where its coming from?
Rectification work replace seals/repair leak...replace diverter valve assembly.
Kindly
Richie (UK)
Posted on Dec 20, 2008
  • 2692 Answers
SOURCE: walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Posted on Mar 20, 2009
  • 297 Answers
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
Posted on Jul 16, 2009
  • 349 Answers
SOURCE: adjusting the scauld guard on a shower mixer valve
Uue a 1/8" allen wrench to remove handle to access the dial that set's the mixture of water.Remember or mark where it is and remove and reinsert counter clockwise about a 1/4 turn to start to you reach desired temperature setting. Be careful not to set it at a hot enough setting to burn you.
Once dial in place slide handle on and turn on to check water temperature.
Posted on Aug 01, 2010
How do I adjust water temperature on a Pegasus shower head?
Adjustment is usually on the valve assembly. Take off the big round trim ring and you will find the adjustment on the valve assembly or in the valve stem.
Oct 19, 2014 | Pegasus F1226700RBP 1100 Series Single...
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Have a pegasus shower single valve ..cannot determine how to adjust the hot water to increase it. Have hot water in bathroom sink.... renting this place...owner has no clue. removed handle and all that is...
when it is sold the anti-scold is set at cold to protect the buyer -the piece with the groves on it is the stem their should be two plastic clips a red and blue that slid over it these clips are the adjustment -also give pegasus a call they have an 800 number to assist u or home depot the carry the brand
Nov 09, 2009 | Union Pegasus F1228100PBV Series 5000...
Single handle shower valve.. can't get any hot
factory set is usally cold for safety. remove handle, then remove cover. you will see the mechanism, bunch of plastic teeth, set it up in the middle, then try it, repeat process till you get desired temp
Aug 01, 2009 | Home
My shower has been leaking for months. someone
turn the water off to the shower,sometimes you must shut down the whole house at the main ,near the water meter,then take the handle off slide the clip in front up and out then pull posi-temp straight out.replace posi-temp in reverse order.be mindful of the H/C indicator on posi-temp this will ensure you have hot and cold on right sides,if reversed just flip posi-temp.
Jul 08, 2009 | Moen & Posi-Temp Single Handle Shower Or...
I can't get hot water from the pegasus shower valve
The antiscald device needs to be adjusted. It's behind the escucheon and determines the amount of hot water flow.
Jan 13, 2009 | Union Pegasus F1228100PBV Series 5000...
Shower head leaks water when water is turned on
take out the cartridge from the fixture and make sure it has all of the "O" rings and stoppers.
look at the instruction again, make sue you are installing it the right side up. if all that, the shower still leak, then you need to talk to the place you brought the fixture, it may have a defective cartridge.
Jan 10, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Leaky posi temp shower valve
Kindly
Richie
Dec 15, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Home Logo
27 people viewed this question
Top Pegasus Technologies Home Experts
john h
Jim Goldsmith
Jim Goldsmith
Paul Carew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
