Question about Frigidaire FRC445GM Stainless Steel
Frigidaire FRC445GM sometimes cools, sometimes does not
Frigidaire frt045gm cools sometimes then stops then cools
Hello Sheli, thank you for your post!
I understand that your Frigidaire refrigerator will stop cooling occasionally. This could be a possible issue with a component of your sealed system. Please contact your manufacturer directly for additional assistance with your refrigerator. -Matt
Feb 01, 2016 | Frigidaire Refrigerators
How do I defrost my FRC 445GM Refrigerator? I don't have the product manual and wonder if I just unplug it where the melted ice will go.
if its a frost free it should defrost its self. if this is a freezer there is a plug in the bottom and a drain port in the front or side of a chest type uprights have a dished bottom for the water collection. If the frost free wont defrost its self the controller or heat element may be bad and needs to be replaced
Aug 15, 2014 | Frigidaire Refrigerators
Frigidaire does not cool and sometimes shocks you
Good morning friend, thank you for your post!
I understand that your Frigidaire refrigerator is not cooling and will shock you. I would recommend you having a technician come out to your home to properly diagnose and repair your appliance. Normally if it is not cooling we could provide some troubleshooting but with you appliance discharging electric energy I would recommend service. I hope this is helpful. -Matt
Aug 09, 2014 | Frigidaire Refrigerators
Frs6lf7fs4 not cooling or freezing
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FRS6LF7FWS4, is not cooling or freezing. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and listen for the compressor to turn on. Secondly, clean underneath your refrigerator as well as well as behind it with a vacuum cleaner. Lastly, check to make sure that the doors are sealing correctly. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best regards-
WP
May 31, 2014 | Frigidaire FRC445GM Stainless Steel
This model FRC445GM of mine has stopped running is there a reset button. Fridge is only 2yrs old
Good Afternoon Lenette,
I understand that your Frigidaire compact refrigerator, model# FRC445GM, has stopped running. There is a way you can reset your appliance. You will want to unplug it for 3-5 minutes. Once time has passed, plug it back in. If your refrigerator is still not cooling, I suggest contacting either the manufacturer, or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire FRC445GM Stainless Steel
I have a side by side and sometimes water runs out of the freezer side.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 26, 2010 | Frigidaire Refrigerators
Refrigerator installed under counter and stopped cooling
possible bad compressor. check amp draw of compressor. tech info is usally on model # tag on amps. If amps close to recommendation you could need a start kit but more than likly a compressor .
Mar 05, 2010 | Refrigerators
My frigidaire side by side isn't cooling properly,
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 21, 2010 | Frigidaire Freezer Refrigeration White...
Sometimes it blows cold, sometimes it doesnt.
The coils that are located right behind the filter need to be cleaned extremely well. You can purchase a spray from your local hardware dealer that can clean the coils. Also, rinse the fins at the back side of the unit as well. Dirty units can cause this to happen. If you clean it and it continues, you have developed a refrigerant leak. Since window units are so inexpensive today, it is not cost effective to hire someone to come out and find and repair it. Hope this is of help to you.
Apr 11, 2009 | Frigidaire FAC052K7 Air Conditioner
Frigidaire FRC445GM Stainless Steel Logo
41 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
