Question about Fineline Settings 2516WH Full Size Extra Heavy Forks Boxed-1200 p
1991 gmc sierra 1500 350 not heating and guage barely registers
1991 gmc sierra 1500 350 engine will not heat and temperature guage barely will register
Your thermostat has malfunctioned and is stuck open. This is a safety measure to prevent the engine from overheating in the case of failure. Change Thermostat and Gasket.
Feb 11, 2014 | Fineline Settings 2516WH Full Size Extra...
1991 4 x4 gmc sierra 1500 rear wheel seized
if both wheels are not turning look into the diff. but if only one tire is seized check for a brake problem.
Nov 03, 2013 | 1991 GMC Sierra
I have a 1998 gmc sierra 1500 that died when i gave it gas after putting it in gear. after it died i tried turning the ignition again and my guage read it was not charging but there was a buzzing sound...
First, check your alternator/serpentine belt for breakage/integrity. If you successfully re-started the engine after this incident, but your "volts" gage did not register as charging, your problem is likely alternator/belt-related.
Sep 26, 2013 | 1998 GMC Sierra
2003 gmc sierra temp gauge needle stuck in 5 o
Bad IPC.......If u can round up a tech 2 scanner, do a guage sweep and i bet u will see the temp guage will not operate correctly......a new IPC (Instrument Panel Cluster) is really the only fix. Once installed it has to be programmed. If u need any help send me a return message.
Jan 23, 2010 | 2003 GMC Sierra
Speedometer, gas guage, tack all quit working.
Sounds like you have blown a fuse check your fuse box and replace any fuses you find. Hope that helps
Oct 05, 2009 | 1999 GMC Sierra
1991 gmc sierra and white smoke
head gasket blown, or cracked head.
coolant is making its way to the piston and combusting with the gas.
1 or both routes are the only possible way.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 07, 2009 | 1991 GMC Sierra
My 1990 gmc sierra 1500 temp. guage stuck after new thermostat.
Hi
Does your temp guage needle drop to Zero when you switch off ignition ?
If not, your temperature transmitter is faulty, or the wire running to it is earthing out somewhere.
Hope this is of help.
Good Luck !
John.
Jan 16, 2009 | 1990 GMC Sierra
GMC SIERRA 1991 HEAT NOT WORKING
be more specific,head unit could mean cylinder head/s could mean thermostat unit,were the hoses hooked up right? thermostat should be checked before installing,very easy to do could be stuck shut.was the heater core checked or flushed out?lots of maybys,wish it was in my garage..
Oct 16, 2008 | 1991 GMC Sierra
Fineline Settings 2516WH Full Size Extra Heavy Forks Boxed-1200 p Logo
893 people viewed this question
Top Fineline Settings Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Fineline Settings Retail Supply Expert? Answer questions, earn points and help others
