Question about Krups XP5220 Espresso Coffee Maker
Krups XP5220 espresso coffee maker
The coffee is luke warm
SOURCE: Krups Caffe Bistro 867 Expresso & Coffee Maker INSTRUCTIONS
http://www.krupsusa.com/All+Products/Coffee+Machines/Espresso+coffee+machines/Products/867+Bistro/867+Bistro.htm
Posted on Aug 21, 2008
  • 79 Answers
SOURCE: FME2 Coffee Maker
From page 9 of the manual:
Setting and Adjusting the Clock
• The machine must be “off“.
• Press and hold the prog button (o) for 3 seconds: the hours will blink “88 _ _“.
• Adjust the hours in steps by pressing the h/min button (n).
• Press the prog button : the minutes will blink“ XX 88“.
• Adjust the minutes in steps by pressing the h/min button.
• Confirm the setting by pressing the prog button.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.krupsusa.com/Consumer+Services/Product+Support/Results/Manuals/ResultManuals.htm?SelectedService=Manuals&SelectedGuIDService={FA4AA2D9-9799-4F8F-8136-8FEB029407FD}&SelectedProdRef=FME2
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: instructions for Krups Gusto espresso maker
I found the manual on an Amazon.com site for the Krups Gusto espresso maker (January 2009)
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000052280.pdf
Posted on Jan 18, 2009
  • 39 Answers
SOURCE: Krups XP2070 coffee machine -
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Posted on Dec 29, 2009
SOURCE: I have a Krups type 964 espresso maker - I can't get a good seal
the seal on the filter is broken? its a replacement part
Posted on Jun 23, 2010
Need to open front panel to check defective switch on front panel
there is 4 skruws from the front you will seen them remove the filter holder and you will see on the age if it and you have some at the back then you lift up slowly from the front upwords
Oct 10, 2015 | Krups XP5220 Espresso Machine, Precise...
Luke warm coffee
check the temprature settings.
Oct 08, 2008 | Saeco Royal Digital Plus Coffee...
How do i prime an xp5220
You should be really need to prime it all. Check where the water reservoir is installed for blockages or dirt. There should be O-rings present, these may have become dislodged.
Feb 08, 2014 | Krups XP5220 Espresso Machine & Coffee...
Pump may be broke
Remove the frother nozzle: if its the early type with three hooks, slide the frother body down before trying to remove it. Disassemble the frother and clean the three holes in the end. If the holes are blocked, the steam can't escape. If it's not pushing hot water through the coffee holder, pull out the water reservoir, and remove and clean the grid plate assembly where the coffee holder clips in.
XP2280. Where can I obtain an owner's manual?
Krups XP1500 Instructions ' eHow
www.ehow.com > Home
Krups XP1500 Instructions. The Krups XP1500 is a coffee machine and espressomaker with a 10-cup coffee capacity, pause and serve feature, non-stick ...
KRUPS XP1500 USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > ... > Coffee Maker > XP1500
Translate this page View and Download Krups XP1500 user manual online. Krups XP1500: User ... Coffee Maker Krups ESPRESSO COMBI XP1600 User Manual. (51 pages).
Krups 867 Instructions For Use Manual - ManualsLib
www.manualslib.com > Brands > Krups Manuals > Coffee Maker > 867
Coffee Maker KRUPS ESPRESSO NOVO 2100 PLUS Instructions For Use Manual ...Coffee Maker Krups XP1500 User Manual ... stronger brew than regular grammablecombination ber to NEVER open the coffee, espresso, and coffee.
Jun 20, 2012 | Krups XP Coffee Makers & Espresso Machines
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
How do you descale the machine
my machine has stopped working it sounds like the motor is still running, not sure where to buy the descaler can I just use vinegar?
Jan 28, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
I have krups xp 5220 and it doesn't make foam. There is just black caffe. please help me. thank you :)
Three things to try:
1. Try a finer ground coffee
2. Use fresh coffee not old coffee
3. Make sure the coffee is pressed down well in the filter holder
For the machine, make sure it has been descaled correctly.
Hope that helps.
Nov 03, 2010 | Krups XP5220 Espresso Coffee Maker
Krups FME2 Error Message
if you still have the receipt, you can get it repair or replace under the warranty, unless the warranty is for 90 days. in that case you are toast.
time for a new one.
replacing the parts is half the price of a new one.
Oct 20, 2008 | Krups FME2 Coffee Maker
Krups XP5220 Espresso Coffee Maker Logo
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
