Question about Volvo Oil pressure sensor. oil temperature gauge oil pressure gauge 240
Where is oil sensor for a 2001 Volvo?
I am replacing this part.
Can a camshaft position sensor be tested by an ohm meter. Have 2001 Volvo S40. Has spark and injectors spray fuel.Timing marks good, belt replace year ago. Code 2nd bank misfire.
I WORK ON VOLVO TRUCKS BUT I HAVE A GOOD UNDERSTANDING HOW THESE THINGS WORK, I WOULD REPLACE THE CRANK AND CAM SPEED SENSORS.
Feb 16, 2017 | 2001 Volvo S40
Volvo c70 2001. blown engine. Have now replaced engine/used old throttle body but car difficult to run and hard to start. surging badly will not idle/stalls
on google:
2001 Volvo C70 Problems - RepairPal
repairpal.com > Problems > Volvo > C70 Problem with your 2001 Volvo C70? Search our list of user submitted and RepairPal verified problems and issues
Jul 20, 2015 | 2001 Volvo C70
Oil pressure
Likely suspects:
low on oil
worn out oil pressure sensor
worn out engine bearings
Have the problem diagnosed before you blow up your engine.
Feb 26, 2014 | 2001 Volvo V70
2001 VOLVO S80 T6. Failed sensor caused transmission destruction.
They are solenoids that go bad. If you replace one, replace all four solenoids. The kit costs about $100 on ebay. It is a difficult job gaining access to the inside of transmission. Pay someone that knows how it's done.
Aug 10, 2017 | 2001 Volvo S80
Oil pressure warning on 2001 Volvo v70 with 220Km
2 things i would do professionally first. 1. change the oil using a higher weight and a volvo oil filter(there is a difference) 2. have a "wet" gauge installed at the oil pressure sending unit to verify oil pressure from cold to warm. a "wet" gauge is a gauge that reads actuall oil pressure and not the use of electronics. it is usually very acurate. if the oilp pressure still drops, then you are looking at an oil pump issue most likely.
Jan 24, 2010 | Volvo V70 Cars & Trucks
My 2001 v70 volvo runs lean. what does this mean?
o2 sensors need to be replaced. Just using more air and less fuel
Aug 27, 2009 | 2001 Volvo V70
2001 Volvo S40 sensors?
abs control module
Jun 30, 2009 | 2001 Volvo S40
2001 volvo s80 clicks but wont start
i would check if batt cables need cleaning or if batt needs replacing 1st. 2nd make sure its in park .could be loose, disconnect or broken wires,camshaft or crankshaft position sensor. hope that helps
May 17, 2009 | 2000 Volvo S80
Is the oil drain plug and filter located under the plastic skidplate like guard under the car?
Yes. I beleive there are 4 bolts that hold this on. Also, the oil filter has a replacable element inside the outer plastic shell.
May 16, 2009 | 2001 Volvo V70
Oil leaked into radiator after it over boiled
strip and repair job here head off skim and rebuild ,then sort fan out new sensor and possibly a new fan ,is their two fans on this model or a two speed single one ,cant remember been a while since i done one.
Nov 13, 2008 | 2001 Volvo S60
Volvo Oil pressure sensor. oil temperature gauge oil pressure gauge 240 Logo
907 people viewed this question
Top Volvo Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Volvo Measuring Tool and Sensor Expert? Answer questions, earn points and help others
