Question about Stanley Pprh5 450-amp Professional Power Station With Built-in Air
Broken air hose
Air hose nozzel broke off how do i fix it
The plastic valve connector on the compressor hose broke off.
Where do I get another connector?
Posted on Jan 09, 2015
Why do I have soot in the drum?
inproper combustion, oil air mixture not wright change oil nozzel, sound like it is worn out, if new nozzel open up air band a little more to inject more air
Dec 22, 2015 | Heating & Cooling
Kitchen aid KUDP021R does not drain
test this steps and fix it. God bless you
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#3#ixzz2aaqbXzEw
Jul 30, 2013 | Dishwashers
I have a unit with no exhauste hose conecter and no nozzel fitting covers or a window panel
Sadly this company seems to be out of business and parts unavailable. You can get vent hose at lowes. I attached the hose to a unit with a couple of small metal brackets, zip ties and vent tape. For the window part, I cut a piece of plywood, painted it white and cut a hole for the vent hose. Attached it with zip ties and silver vent tape.
May 24, 2012 | Windchaser PAC9 Air Conditioner
Washer fluid won't come out pump working fine not frozen either
If you know the pump is fine then remove the hoses from the nozzels and see if it will pump fluid through to that point. If not the line may be obstructed. If you can pump fluid through to this point clean or replace nozzels.If the line is obstructed remove the other end of the line from the pump and see if you can blow air through it.If you can not blow air through the line repair or replace it.Good luck.
Dec 07, 2010 | 2001 Ford Windstar
I have a B&K kitchen faucet (LM#203120) in my 2005 Newmar motor home. The spray wand has recently broken. The spray wand is approximately 6.5 inchs long and is connected to the water line by means...
If you are talking about the standard spray nozzel with trigger type control than replacement sprayers are reaidily available. You should be able to unscrew flex hose from nozzel at the base of nozzel where sprayer goes into holder on sink.There should be ribbed section on sprayer where flex hose goes in. Grip that section and turn upper section of sprayer counterclockwise to remove. Most hardware stores will have replacement nozzels for under ten dollars. Hope this helps. Thanks
Nov 12, 2010 | B&K Plumbing
Want to blow air out to inflate mattress
You need to remove the main head with the brushes from the front and install the safety cup. The remove the bag by unclipping from the top and disconnecting the boot end from the bottom with an outwards twist. Now attach the hose to the exposed outlet; attached the thin nozzel designed for inflating to the hose and switch on - you will feel air being expelled from the hose.
Air, which normally contains dirt and dust because you're hoovering is blown into the bag, but now with the bag removed; the air is blown into your hose, through the attachment and into what ever needs inflating.
For a good visual set of instructions click on the following link and scroll down to the second set of instructions :
How to change hoover to a blower
Sep 25, 2010 | Kirby G5 Bagged Upright Vacuum
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
My vacuum hose won't power on but the vacuum in the attic powers on
I guess you are talking about the power nozzel not working. Try pushing the reset button on the top of the power nozzel first. Make sure you have the switch on the hose handle is in the right possition. If it still dosen't work, you could have a bad switch or a broken wire in the hose itself. If this is the case, you'll have to take it to the shop. All you need to take is the hose and the power nozzel.
Oct 18, 2009 | Electrolux Central Vacuum
Windshield washer not working properly
If you have used ANYTHING beside windshield solvent in you reservor, you may have created WAXING from soap in the bottom of washer tank, which clogs pump,lines, and nozzel....take the tank out and wash it..disconnect washer hoses at nozzel and clear with compressed air along with the nozzel...if you use solvent only you may have a worn washer pump or restriction...check those and good luck.....
Jul 04, 2009 | Ford Five Hundred Cars & Trucks
My 2003 Harley Ultra rear shocks hve no spring left in them, they bottom out at bumps etc. The bike has 10K miles on it.Is there a fix or do I need new shocks? Seems like low milage for shocks to go bad.
Your ultra has rear air shocks. on the right side of the bike in the area of the fender is an air valve to install air. Do not add anymore then 25 lbs. a hand pump is safer an air compressor or gas station can have so much pressure it will blow the seals before you take the nozzel off. You will have to remove your hard bag to see the air input. Looks like a tire air nozzel should have a silver color cap on it.
Jun 13, 2009 | 2005 Harley Davidson FLHTCUI Electra Glide...
Stanley Pprh5 450-amp Professional Power Station With Built-in Air Logo
208 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
