Question about Breville Kitchen Appliances - Others
The plug is loose
The plug moves.
I have a 2000 katana and recenly move i drove my bike in to a moving truck went i took the bike down it wont star dont have spark in the spark plugs need help?
Hi, Destiny and the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
97 gsxr600 no spark
http://katriders.com/vb/showthread.php?t=134012
http://www.carlsalter.com/download.asp?p=1557
OEM parts for Suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 10, 2016 | 2000 Suzuki GSX 600 F (Katana)
Door lock
It is a simple short in a wire, or the plug that goes into the switches is loose. I would suggest taking the plug loose, and applying some dielectric grease to the pin holes, and then see if that fixes it.
Jul 14, 2014 | 2009 Chevrolet Impala
No sound on my tv
check the connector on the speaker might get loose, if ok re soldered cold soldered component parts in the amplifier section of the main board.
Aug 15, 2012 | Sharp Televison & Video
Toshiba dvr17kb,load vcr tape in and loads for 5 seconds the the machine turns off
Good day!!
At first move..try to wiggle/move the wires of your toshiba if that move didn't work try to check the plug if it is plug in accurately maybe it was just loose then if this move does not work out then please message me/comment me.
Thank you!!
Hope to help you...
May 27, 2011 | Televison & Video
I have a rowenta proffesional luxe iron but the cable keeps turning it off so when i move the cable it goes back on and when i am ironing it shuts off
you have a open circuit that occurs due to a wire loose at the plug end or a loose connection within the iron. a break in the cable will also display the systems you discribe. check for loose connections before you decide to replace the cable. by keeping the cable stationery when the iron is on at the plug end check wether it switches off when you move the cable near the plug end.if it switches off the loose wire is in the plug if it does not the try the moving the cable nearer the Iron end.
Apr 10, 2011 | Rowenta Professional Luxe DM880 Iron
After moving frigde and freezer quit.
Your compressor start relay has become loose or possibly defective.
Push it back on for a good connection.
Watch it when you plug the fridge in.
If it sparks replace it.
Mar 12, 2009 | Frigidaire FRS23KF7AB Side by Side...
No power in surround sound system(DVD/subwoofer)
The key could be the word "move".
Electrical items can get knocked moving and something might have become loose or damaged inside the sub. So check it out. Inside too!
Feb 28, 2018 | JVC TH-C3 System
Rear projection - only blue lamp works, after set was moved
since you moved it i would look for a loose connection or loose board and loose plugs
Dec 22, 2007 | Mitsubishi WS-65809 65" Rear Projection...
Kitchen Appliances - Others Logo
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
