Question about Bose Wave music system Multi-CD Changer 3-Disc
Manually eject cd from bose multi cd changer - Bose Wave music system Multi-CD Changer 3-Disc
  • 23 Answers
SOURCE: Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Posted on Mar 18, 2009
  • 23 Answers
SOURCE: bose wave muoti cd changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will have to be disassembled to get the CD out and the unit itself will need to be serviced (rebuild and retime cd changing mechanism)
  • 6 Answers
SOURCE: Multi cd bose player will not eject 4th cd.
OK, this problem is everywhere with the bose cd changer addon. Many people can still play a cd with the top one fine, but cannot get cds to eject and/or read in 3 disc changer. My friends mom had one and after finally hearing back from bose, they said send it in with $100 to get fixed. If you have to send in and you value your cds, you may want to open it up and get them out. Use this at your own risk, there are no warranty stickers I saw and there will be exposed voltage, shock hazards, etc.; so if any of this worries you, stop here. By proceeding, you are admitting that you are capable of minor repairs and therefore I'm not responsible for any damage or harm caused. OK, here it is:
Unplug everything. On the bottom of the cd changer unit are 4 screws (silver ones recessed about 3/4" or so, use phillips screwdriver) to remove. Turn unit upright again and lift cover slowly straight up. In the front of the unit is a ribbon cable you will want to disconnect that goes to the cd 2-4 lights. Take note which side the dark blue tab is on and gently pull out by dark blue tab, rocking side to side if needed) You can then pull cover all the way off and set aside. Plug power into back of cd changer (careful not to touch anything inside) and see if the cds want to eject now. If not let the initializing process finish and repeat. This time see if you can gently help the cd out. The problem may also be the spindle not lowering, you can look for this movement during the last step of init. process. Work your way fom the top tray down removing the cds gently, remember we open it up because they were valuable to us, don't destroy them now, and don't ever use anything that could possibly scratch either top or bottom of the cd, use edges instead. Start to replace cover making sure to reattach ribbon cable back into socket the same way it came out. do not force too hard or you may crease and break ribbon. Gently replace cover and grab both top and bottom to turn over. Replace 4 phillips screws making sure not to overtighten or cross-thread. Now you may return to bose or just find an independent repair shop in your area, they are usually quicker, more polite, usually cheaper, and best of all, local!
Posted on Oct 28, 2009
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
  • 23 Answers
SOURCE: I have a bose wave
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Posted on Jan 30, 2011
How can I eject my stuck cd multi-cd changer
Had the same problem with mine.....turn it over in your lap and give it a slap..not to hard. that should work. If not, remove the cover and flip the release button located in back. good luck!!
Jul 27, 2014 | Bose Wave music system Multi-CD Changer...
I have the same problem with Peggy, I checked all the connection, and still, no lights on the changer, does not play nor ejects..please HELP, Nona
It is now time to get BOSE to stand behind their product- they sure charge enough for their product. Call them and complain and don't let
them off the hook. Tell them you will place complaints against their product on the internet. I bet there are some there now.
This is why I do not buy any of their stuff.
Dec 06, 2012 | Bose Wave music system Multi-CD Changer...
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
No light on cd changer, dosnt eject cd's?
Hello
Its power supply system has some trouble. It is best for you to contact authorised Bose service centere, since some critical components are there on their power supply ststem, which you can't get it from anywhere except from them. Moreover, the schematic diagram of Bose equipments are very difficult to get. Never try to repair it by yourself, as it may spoil the set. OK.
Nov 22, 2010 | Bose Wave music system Multi-CD Changer...
I have a Dvd stuck in the CD changer in disc 1. It won't eject. How can I get it out.
on the front face of the dvd is a tiny hole which you slide in a rod or pin which releases the locking catch
Jul 05, 2010 | Bose Wave music system Multi-CD Changer...
Bose
PO Box 9168
The Mountains
Dec 01, 2008 | Bose & Wave& Music System
Dec 23, 2007 | Bose Wave music system Multi-CD Changer...
Bose Wave music system Multi-CD Changer 3-Disc Logo
56 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
