Question about Danby DWC283BLS Wine Cooler
Danby dwc212bls wine cooler fluctuates in temperature
SOURCE: how to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Posted on Jul 06, 2008
SOURCE: danby wine cooler repair
I am having a problem with my wine cooler also.I found the upper evap fan not running.So i opened up the control board and plugged the fan that was not working into one of the other 2 sockets,and the fan worked.so i have a circuit board problem.If you go online to sears parts and repair.put in your model# and search,it will bring up a diagram of most of the parts available.And no it doesnt have to be a GE product.
Posted on Jul 08, 2008
SOURCE: wine cooler noise
I wrote up a blog entry for a minor modification we made to our Danby wine refrigerator to silence noise from the upper fan:
http://www.adrianmccarthy.com/blog/?p=79
You can find quieter versions of the fan with the same specs at big computer parts stores (for the PC builders who want quiet computers). The one we got cost less than $20. We also added rubber spacers so that the fan vibration isn't amplified by back panel of the fridge (which otherwise acts like a soundboard). Made a huge difference.
Even with the fix, though, I wouldn't ever recommend the Danby models. Their noisy, and we've had multiple breakdowns in five years. The only authorized repair shop in our area has lousy customer service and high prices.
Posted on Sep 29, 2008
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
  • 1739 Answers
SOURCE: danby wine cooler not cooling
This product is now retired however was able to locate your manual here:
http://www.danby.ca/cms/uploads/products/en_manual/DWC283BLS_%28web%29.pdf
Verify you have power to the unit?
Have you provided proper spacing of 5" between the unit and any adjacent wall? Note these are free- standing units and are not meant to be built in.
Make sure it is not located adjacent a heat source or in direct sunlight.
Check to make sure you have set the temperature controls correctly. See page 4 of the manual. Note if the power is interrupted your settings are erased and the cooler will default to the preset temperatures.
if you have power and the temperature settigns are correct ther eis likely an issue with the compressor and it may need to be serviced.
To find your nearest service dealer go to the following site:
http://www.danby.com/language_sel.php?ref=%2Flocator.php%3Ftype%3Dservice
Select your county and then click on Service in the horizontal menu bar.
Posted on Jun 05, 2011
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
Need to reset temperture
Please have a look at page 4 of the product manual where step-by-step directions are provided for setting your desired temperature.
http://www.danby.com/cms/products/en_manual/DWC283BLS_%28web%29.pdf
If you have any further questions, please do not hesitate to contact Danby Customer Service via 1-800-26-DANBY
Hours of Operation Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Jun 03, 2012 | Danby DWC283BLS Wine Cooler
How do u set temp in a Danby wine frig?
May 05, 2012 | Danby DWC283BLS Wine Cooler
Cannot get Danby Silhouette 166 dual wine cooler to change temperature. It stays at 70 (both upper and lower). Can you help. Just bought used brought it home and it won't cool.
I also just brought home a used Danby Silhouette 166-bottle wine fridge and it is not cooling. Did you have someone come look at yours and did you get it fixed?
Jul 13, 2011 | Danby Silhouette® DWC276BLS Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
50 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
