Question about Panasonic CT-32SL14 32" TV
The direct tv bow won't work with my 1997 panasonic tv
We can't get the cable box to connect to the tv to produce picture and sound we also tried to hook a xbox 360 to the red yellow and white connectors on the back and that would not show up on Video 1 or 2
  • 65 Answers
SOURCE: Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Posted on Dec 09, 2006
  • 192 Answers
SOURCE: Component Video inputs do not work
I started back in the day of tubes. A family would have one set and it would be a 19" black and white. There are different resolutions now. The components probably do work, but, they don't pass the 480i signal. The satelite converter's analog signal needs to be set to 480p and the DVD needs to be set to progressive if it does have that setting. If the DVD is not a progressive scan DVD, then, the only inputs that it will show on is the analog signal. Some of the dish converters have a switch on the face for changing the resolution. If yours doesn't then put it in an analog source and go to the menu and change it there. Then move it to the component input. Hope this helps.
Posted on Jun 24, 2007
  • 205 Answers
SOURCE: picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Posted on Jan 01, 2008
nick_helpap
  • 334 Answers
SOURCE: can't get xbox 360 to work on tv
u must use 480 p out put on xbox 360 wqith xcounpunt vcable only 720 p with hdmi on this ok boss thx nick so get xbox on reg tv so u can see pic with yellow cable came with then turn back to 480 p mode ok thx nick
Posted on Oct 12, 2008
SOURCE: No picture when connecting CRT TV to Panasonic DVD/VHS Combo
If you combo get activated the progresive scan function you never see the videio only sound you need to deactivate
Posted on Feb 14, 2009
Hi I have a panasonic viera tc-p58s2. It was connected through hdmi to my sound system. Suddenly I got no picture. I disconnected the hdmi cables, tried different cables still no picture. I connected the...
Disconnect the cable on both ends. Unplug all components. Reconnect the HDMI cables how you want it set up. Then power up the system again and let it start up. Make sure all the video and audio inputs are properly selected and you should be good to go. HDMI is a pain and quite often on mismatch equipment has to be re-trained. If that does not work let me know and I will help you troubleshoot a bit deeper.
Jul 03, 2014 | Televison & Video
When I connect my Panasonic PT-43LC14 to my cable box using an HDMI cable I get a green screen. I can hear the sound, but no picture. When I connected my Blue-Rey player the HDMI port worked fine.
U have a old version of firmware in ur cable box or ur cable pakage don't have HD service.Tries find out if ur subcribe package have HD serviced and trade in ur old cable box.Not ur tv or a cable box malfunctions.
Jun 12, 2011 | Panasonic PT-43LC14 43" Rear Projection...
I have picture but no sound. We just had our surround sound system go out and are trying to run our tv on it's own internal speaker system. How do you hook it to our direct tv hd box
Hi.
You need to use audio cables. Connect two red and white audio cables from the output on the HD box to the relative input at the back of TV (nr.4 in picture below). The best way to connect the HD box is by using component cables, that are the red-green and blue trio of cables, plus a white and red audio cables.
Here what you need:
Three plus two:
Component Video Cable
Audio Red / White Cable
or single set of five:
Cables Unlimited - Video / audio cable
Once you have the five cables, connect them to the output at the back of the Direct TV box, and then connect the other end of the cable to either group of connectors 6, or to one of the columns in connector 7. Do connection with box and TV power off. After re-applying power use the source-input selector on remote to select the source from Direct TV box.
May 24, 2011 | Samsung HCM4215W 42" Rear Projection...
How should I hook up my xbox to the back of the television using the red, white, and yellow wires? It is hooked up but I am not getting any audio. Thank you.
First make sure your video cable is set to TV not HDTV
Then plug the 3 RCA cables into the color coded slots on the TV. Make sure you aren't using the red cable from the component RGB but are using the red cable for sound (next to the white one).
Then, if you still have no picture, start the console using the controllers Xbox button and hold "Y" and "RT" until the console restarts. this will reset the video settings on the 360 to default.
Follow this guide if you get confused:
http://support.xbox.com/en-us/pages/xbox-360/how-to/audio-video-devices/connect-xbox-360-console-tv.aspx
and for the video reset about halfway down the page:
http://support.xbox.com/en-us/Pages/xbox-360/troubleshoot/xbox-360-top-issues/tv-or-monitor-screen-is-blank-while-connected.aspx
Mar 30, 2011 | Video Game Consoles & Games
Here's my setup: 46"Panasonic Viera
I'd call the cable company, it sounds like you have an issue with the cable box.
Feb 22, 2011 | Televison & Video
I have a 55" LG
Easy solution; this is a very common problem. Connect Cable or satellite box / DVR directly to one of the TV HDMI inputs. Connect an optical audio cable from that box to receiver so sound is surround through your speakers. You cannot connect DVR directly to receiver because the anti pirating chip will shut off the picture and produce a green or no screen at all.
You can, however, connect a BD (Blu-Ray) player via HDMI cable directly to your receiver without that problem. Connect HDMI output from receiver to a second HDMI input on the LG.
Contact me if you need more help! All the best, John
Nov 14, 2010 | LG INFINIA 55LE8500 LED HDTV
In my tv i have connected set top box to av3 i can see the pictures but no volume. i have have a dvd payer connected to HDMI1 and it is working ok. it used to work ok but some how there is no volume...
When it is certain that the volume on the TV functions properly try to ensure also that the set top box also produces volume. This you can do by connecting the set top box directly to your DVD auxillary channel. If any volume comes out of that then you can be sure the fault is from your connection. But if on the other hand the the box does not produce any volume then the set top box is faulty. Therefore you have to send it back to your supplier.
Hope this solution has been helpful?
Sep 26, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
No picture or sound with brand new xbox friend's xboxs worked ok
Look like ur Xbox 360 AV RCA cables is not making contact to the input board very well.Take some rubing achahol cleans the all those input holes,take the RCA AV connections make couples twises to the red,yellow and white,will help.Make contact with ur input board it should work.
Apr 28, 2010 | Zenith SY2551S TV
HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Nov 27, 2009 | Hitachi 51F59 51" HDTV Projection...
Panasonic CT-32SL14 32" TV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
