Question about Ricoh Aficio CL3000 Laser Printer
A blank vertical line appears on every page printed
Everything prints fine with the exception of this one blank vertical line
  • Ricoh Expert
  • 155 Answers
If it is a white void check laser shield glass. toner might be on it causing this problem. There should be a wand in front door use to clean laser area make sure you do each color. hope this helps.
Posted on Nov 14, 2014
Marktron
  • 7 Answers
SOURCE: vetical lines printing on page
print a coulr sample page from internal memory and if issue is present it is a physical issue with the colour pcu, if it doesnt happen on sample page, then check driver versions- update
Posted on Feb 15, 2008
Gunslinger
  • 62 Answers
SOURCE: ricoh 1045 only printing on 1/2 page
Check the glass **** next to the area you slid the developer unit into. Chances are it is half covered with toner.
Posted on Jul 07, 2008
  • 3 Answers
SOURCE: Black vertical lines on printed pages
check the "photoconductor unit" (pg 37 in the Maintance manual)
ours was doing it with the magenta and saw a faint 'scratch' on the roller. will attempt to replace and report back if this fixes it.
Posted on Sep 19, 2008
SOURCE: white vertical lines on printed page
change the k black drum... its the only solution trust me
thanks
Posted on Mar 09, 2009
Gunslinger
  • 62 Answers
SOURCE: Lanier 5622 Prints vertical lines
Bad PCU
Posted on Feb 10, 2010
HP Laserjet 3052- Printing problem
Your printer's drum must be cleaned or replaced if damaged.
Aug 09, 2008 | LaserJet 3052 All-In-One Printer
Thin broken vertical line 8.15 cms from left edge of paper. Appears on both printed and blank pages
your printing drum got damaged there is a thin line on it that you may see with your eyes. you have to replace it
Aug 22, 2010 | Epson AcuLaser C900 Printer
Vertical lines of missing print
I'd certainly be swapping the fuser first although I know how expensive they can be and what a pain they can be to get at. You've tried everything else I would start with and as the text is smudging I'd certainly be testing the fuser next. Scott.
Dec 12, 2009 | Konica Minolta magicolor 2500 Printer
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Jul 28, 2009 | Xerox WorkCentre 4150/X Laser Printer
Lines in the print
Nozzle check perfect? No ink drop outside lines? Cyan lines is random position. Print blank pages. It is still appear cyan lines? If yes, it caused by waste ink at bottom plate. Print blank pages more, it will clean itself.
Jun 29, 2009 | Epson Stylus CX9400 Photo Printer
Blank line in the middle of the copy
Either the light source is failing or you have a piece of paper stuck in the way of the LED's and the drum.  Check the paper path very carfully to make sure there is no dirt or debris in the paper path.
Oct 30, 2008 | OKI C3200n Led Printer
Scanner leaves three vertical lines on scanned page
A dirty glass base can cause ‘spots’ or blemishes to appear on your final printout. Additionally, if you had some sort of opaque liquid that may have transferred on to the glass base from a previous operation. But the majority of the unwanted vertical lines are generally caused by either a dirty or damaged print roller or faulty LEDs in the Scanner Module.
To separate one from the other you have to check the following:
Do you only see the lines with a Scan operation?
Do your print jobs print fine without any unwanted lines?
If you only see the unwanted lines during a Scan operation, then most likely you have a fault/dirty/obstructed LED module.
If you see the unwanted lines with all print operations (Scan, Print and Copy), then you most likely have a worn out, damaged or dirty Print Roller.
Hope this helps…
RojoSho
Sep 29, 2008 | Brother MFC-7820N Laser Printer
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Blank vertical line on pages
open side door, should be a black assembly there with two wires, is it clean? is there any toner or hair on the wires?
Nov 14, 2007 | Brother DCP-7020 All-In-One Laser Printer
Ricoh Aficio CL3000 Laser Printer Logo
118 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
