Question about Advanced Tech Infrared ATI Heat Pure Elite 5120 BTU Electric Floor Space Heater
Space heater problems
Bought this product and it worked. Then three weeks later, it just stopped. I have power shower on its main power switch because it lights up. But nothing on the board comes on at all. I checked the fuse on an internal board and it's good. Now have it almost completely tore apart on my living room floor. Really need to get it going cuz I have little ones in my house. Any suggestions would be appreciated. Thanks Brenda
Lasko Tower Fan stopped working but Speed switch has power on all but one cable, How to find the issue?
you should only have power on the black wire into the switch. The white wire feeds straight through. the switch breaks the black and routes it to one of the three outputs for the motor.
Aug 07, 2014 | Lasko 2510 36" Tower Fan with Remote...
I have a new (3 weeks) Holmes air purifier. After a week of sitting on my bedtable, I noticed black sooty powder on my bed table and a week later, I found the same powder on the wall. It has ruined my...
Actually, your purifier is working as it should. The black soot is due to the negatives ions which attach themselves to the smoke/dust/dirt particles in the room and make them drop to floor. If you don't smoke it won't be much of a problem. Some minor residue will be found in and around the unit but this comes about because the negative ions make dust and other particulates fall to the floor. A quick wipe or vacuum easily eliminates this problem. Besides, I would rather have them on the floor than floating around in the air, wouldn't you?
Apr 26, 2009 | Holmes Products HAP2400-U Air Purifier
A broken switch on a small portable ozone machine--X-15 or XL
Hi again, epyn,
As I think about this more, I'd say that the switch you have would probably _not_ work. What you have is somewhat like a conventional 3-way switch. With the Alpine/Ecoquest switch, I suspect one terminal is for power to the internal light/LED, one is the load to the switch, and the third would be the ground for both.
If I can be of further assistance, let me know - I'd like to resolve this for you. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using,
Dec 15, 2008 | Alpine Air XL-15 Air Purifier
Brookstone Pure-ion Advanced
i am a low voltage tech my wife told me that our 506840 air cleaner stopped working so being a tech geek i had to know why it just stopped working.when plugged in i heard a click telling me that the main board was getting power.opened the back end where power cord goes to put my meter and voltage was going to the main power coil. but the main board was oxidized. when my wife was cleaning the filters and might not have had the filters completely dried the water was dripping down to main board.the unit to main power source is not design very well where water from cleaning the filters can drip down to main power board.solution i am working on is trying to get a new board when we bought this it was $499.00
Oct 15, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Air purifier can't work.
The best solution is to dump sharper image. I found a few site that had good solid reviews for a better air purifier decision - and
Jun 24, 2008 | Sharper Image Professional Plus Ionic...
I need to buy one filter
we are also expierencing the same crackling problem. This machine is only a year old.....
anyone find anyway to resolve the crackling? I have not contacted Brookstone, but it doesn't sound too promising anyway.
These air purifiers are not cheap and they should back up their products.
May 17, 2008 | Brookstone Pure-Ion (506840) Air Purifier
Water Cooler Problem
you might try a strong solution of vinegar and water and then flush it later till it tastes right
Mar 09, 2008 | Air Purifiers
Sharper image ionic breeze air cleaner
I was able to find the power-on switch to be defective. The switch is a momentary normally off switch constructed of two contacts on a printed circuit board1.gif. After five years, the surface of the switch contacts became oxidized and no longer made electrical continuity when depressed. I rewired the two wires to a new momentary switch and both my Ionic Air Cleaners are working again.
Feb 18, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Will not start up??
Same problem here. Opened it but everythng seemed intact. Red light flashes momentarily during initial plug in. Has power, oscillates but no fan rotation.
Nov 05, 2007 | Bionaire BAP1500-U Air Purifier
Red Light indicator on
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Apr 06, 2007 | Bionaire BAP1500-U Air Purifier
Advanced Tech Infrared ATI Heat Pure Elite 5120 BTU Electric Floor Space Heater Logo
156 people viewed this question
Top Advanced Tech Infrared Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you an Advanced Tech Infrared Air Purifier Expert? Answer questions, earn points and help others
