Question about Pool & Spa
How many gph intex 630 pump - Pool & Spa
SOURCE: Need help downsizing pool pump connection
Okay. I think I gotcha covered.
I have one mocked up here right in front of me.
Still going on the PVC pipe assumption...
- Install a PVC 1 1/2 " - 1" reducer on the new pump nipple.
- Install a short piece (nipple) of 1 1/2" PVC pipe in the reducer installed on the pump
- Install an 1 1/2" MIP adapter (PVC) on the 1 1/2 " nipple
- Screw the hose onto the threaded 1 1/2" MIP adapter.
There are several ways to do this -- the above is a good way.
Have you ever mated PVC piping/adapters with solvent? I can help you with the details of this if your unfamiliar with it...
Charlie
Posted on May 29, 2009
  • 71 Answers
SOURCE: Intex pump 635 is a P.O.S.! How do I hook up a different pump?
I just left the standard intex connection on the pool and I cut the standard connection off of the filter side and I slid the hose over the top of a 1 1/2 pipe and put 2 stainless steel hose clamps over them and it worked fine
Posted on Jul 23, 2009
SOURCE: How do you install the adaptors part number 10722
You cannot use them unless you have a 1 1/2" female adapter for those to screw into.
Posted on Sep 05, 2009
  • 8 Answers
SOURCE: hose hook ups
If you look at the chlorinator you'll see an arrow pointing in the direction of the flow. Basically the water coming out of the pool should be going through the filter tower first and then through the chlorinator and ultimately back into the pool.
Posted on Jun 16, 2010
  • 22 Answers
SOURCE: 2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
Posted on Jun 17, 2010
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Filter/Pump Model 635 replacement parts for the pump
my intex 635 pump impeller is broken i need a replacement part. i do not have the money for a new pump.
Jun 30, 2010 | Intex Krystal Clear Model 635 Pool Filter...
How oprates the timmer in my 2500 gph intex filter pump
When the timer mode is set it will only run for the hours you have the knob positioned to. It will then shut off. You will need to restart it everytime.
Jun 21, 2010 | Intex Krystal Clear Model 635 Pool Filter...
May 18, 2010 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Need an impeller for a model 635 intex pump.
You are correct. Intex is in the business of selling new product. If you have the pieces, they may be super glued with about a 70% sucess rate. good luck!
Aug 12, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Jul 23, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Jul 09, 2009 | Intex Pool & Spa
I have an intex 15 x 48 pool. The old pump wasnt
check the intex site for adapters and other parts you might need.
I don't think you should buy new pool .
Jun 28, 2009 | Intex 4000 GPH Filter Pump
Pool & Spa Logo
41 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
