Question about GE PWR04FANBB Wine Cooler
Dual zones won't stay at programmed temp - GE PWR04FANBB Wine Cooler
Just purchased and is not cooling at all
please see this steps and fix it. God bless you
1. Unit not running
Possible Causes Response a. Power cord unplugged
b. No power at all
c. If display lighting, temp setting high
d. If temp setting ok, sensors or control board bad
e. Compressor unit malfunctioning a. Check for power cord plug
b. Check receptacle voltage & fuses
c. Lower temperature setting
d. Call service for replacing sensors or control board
e. Call service for component check
Nov 27, 2013 | EdgeStar CWR361FD - 36 Bottle Built-In...
I have 2 zones, both of which are programmed. The display for zone 2 works fine. When I am looking at zone 1, the desired heating and cooling temps display as -- with no temps there. The system is set on...
Are these reading temps at 2 separate tstats or are you using temp sensors that send the temp back to the stat. It sounds like the sensor is not communicating with the stat.
Jun 14, 2017 | Carrier 38CKC042 Air Conditioner
2004 pacifica won't stay running. temp gauges are erratic. No code on PCM
The PCM on a 2004 Ford Mustang is a combined control unit, consisting of the engine control unit (also known as an ECU) and the transmission control unit.------------------------------------------------------------------------------------------
Launch X431 Master
Mar 07, 2013 | Chrysler Pacifica Cars & Trucks
95 buick riviera the drivers side and middle dash vents a/c feels like on vent and the passenger side is cold when a/c is on lowest temp setting. Has duel zone control.
riviera uses electric servo motors to control temp with dual zone control.
driver side servo motor has gone bad
please rate this post
Jul 27, 2010 | 1995 Buick Riviera
Replaced heater core. Mt car has the dual temperature zones. Now my passenger side temp wont change. stays hot, What should I do?
Either pass side actuator was not plugged in(rear most unit on heater of the 2 actuators for dual zone),(front unit which is an exact opposite is on the opposite side of the heater on the front side) or flap is jammed inside heater assembly.
Open the glove compartment and unscrew the door to remove.
Look to the left......remove the actuator and move the flap....if it moves and the unit was plugged in replace the actuator for the pass side.
Nov 08, 2009 | 1995 Buick LeSabre
Haier Dual Zone Wine Chiller - One Fan wont run
I have the same problem. When I first discovered this, both fans had stopped working and the temp for both zones was over 80. So much for the wine that had been stored there. After leaving the unit unplugged for a few days, the fan for the lower section started working again but the upper fan is still overheating. Haier customer service says too bad, so sad (I discovered this problem in the 13th month of ownership). I'm sure it is not worthwhile to fix this so it is going out with the trash and I'll look for a different brand for the next wine cellar that I purchase. Any ideas?
Mar 01, 2009 | Refrigerators
Dual climate zones. One hot, other cold, both set on high.
Go to heatertreater.net. I bought one for my jgc and now it's working great. It's the blend doors that are broken. My has dual temp controls but it still worked for mine. The only thing is, the passenger side heat and air temp stays the same as the driver's side. Who cares!!!!!! It's warm and a whole lot cheaper than what the dealer costs. It took approx. 1 hour and $120.00 for the part. I paid $20.00 extra for express shipping. It's getting cold in Tennessee.
Nov 19, 2008 | 1999 Jeep Grand Cherokee
GE PWR04FANBB Wine Cooler Logo
24 people viewed this question
Top GE Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a GE Furniture Expert? Answer questions, earn points and help others
