Question about Indesit WA 115 Front Load Washer
WIXL 143 delay timer and lock lights are flashing fast and washer stops
The Washing machine starts ok when it gets to rinse the lock light and delay timer light starts to flash fast and the machine stops working, it is still on but just chugging. I have cleared filter and washing powder tray. I have done switch power off to reset but the problem still remains
  • 209 Answers
SOURCE: indesit WIL103 flashing lights problem
because of the short time this runs then stops, there could be maybe 3 faults, 1 check water inlet valves and supply for water flow 2 check for any motor action (use another programme) 3 check heater element for open circuit number 1 or number 3 sounds most likely hope i have helped, if so rate me please
Posted on Sep 25, 2007
SOURCE: Indesit Standard WIL 123 (UK) Washing Machine
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
Posted on Jan 11, 2008
jason0110
  • 66 Answers
SOURCE: Indesit WIXXL146 washing machine will not turn on
sounds like interlock or pcb try lock first as this is cheap to replace regards jason
Posted on Jun 15, 2008
  • 197 Answers
SOURCE: lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
Posted on May 09, 2009
  • 105 Answers
SOURCE: I have got Indesit WIXL 123 washing machine. Until
i had the same problem its the motor you need a new one luckly my father inlaw is a scrap collector and i come across a spare washer and salvaged all the parts and i tried plugging a new circuit board but still the same so i tried changing the door lock mechanisim but still the same, so itried just for the hell of it the motor and weyhey we have life i thought the motor was the most unlikely thing to cause the problem but im happy but for how long? next year will replace it with new washer.
Posted on Nov 29, 2009
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Hi, we have an Indesit WIXL 143(UK)washing machine. Both the stain remove and easy iron lights flash together about twice per second and the door lock light flashes faster on doing any wash. Is this a...
This probably happens after the main wash has completed and it is just finishing the first rinse. It seems to be a warning that there is a partial blockage on the waste outflow. Empty the wash and use the DRAIN program to get as much water out as possible. From the FRONT of the machine open the lower flap and and then put a large towel on the floor. Unscrew the big black filter cover slowly - some water will come out -about a cupful. Ensuring the machine is turned off, use a cloth to remove any obvious build up of "gunk". Would suggest using an old toothbrush to clean off the surface and the plug.
99% of the time - Job Done!
You may have a blockage in your waste pipe. (If using an extension check any coupling has not "bunged up".
Last, check your waste pipe / grey water connection. Again, this "should" be fine, but it may be bunged up, especially if it feeds into the sink outflow.
Stick back together, plug in and use the 11, fast wash option in cold. Should now be happy, and you should hear water gurgling away noisily down the waste.
Always worth doing a 2 - 90 extra hot wash once in a while even EMPTY of washing just to "flush the system" now and again.
Hope this helps and saves you a £104 service engineer call from indesit :)
Nov 02, 2009 | Washing Machines
My washer dryer wont spin or rinse,
hello mam
you should call the engineer because he will check the timer switch and the motor if he finds the problem in any one of these he will rectify it.
Oct 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
AWM6140/3 Wahing machine
it's a prgramme timer issue mate, you either need the timer flashing with updated software or a replacement timer
Aug 24, 2009 | Whirlpool AWM6140 Front Load Washer
Indesit WIL103 flashing lights problem
Sep 25, 2007 | Indesit W 123 Front Load Washer
Indesit WA 115 Front Load Washer Logo
70 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
