Question about Bodum Bistro Toaster
Lever won't stay down . Is the problem in the hold down magnet?
Please help
GE toaster model 169100. : the lever to toast won't stay down. I researched removing the base to clean the magnets, but not regular Phillips screws. Suggestions??
I have the same GE toaster and now my lever won\'t lock in place when I push it down to cook my toast. The handle does not pull off and when you turn the toaster over there are no screws to take the toaster apart. So I guess I have to say this is a disposable toaster but I am extremely bummed because it is beautiful and match decor and microwave that has the same color scheme as my toaster.
I wish companies would stop making cheap junk that doesn\'t last more then a few years.
Sep 06, 2013 | GE small appliance toasters 169100 User...
De Longhi CT021.A x 2 slice toaser - Won't stay down
Is it plugged in. You may have to do a little handy work, unplug the unit and look to see where it catches when the handle is in down position, you may have to open the bottom door. There is a little catch when the handle is down it may need to be bent a little not much.
Oct 15, 2012 | DeLonghi RT200 Retro 2-Slice Toaster
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Pilot light on the gas boiler won't stay lit it's
The pilot flame must touch (burn) the tip oqef the t-couple to hold the magnet in the gas value open.make sure the pilot orifice (hole) is clear.the pilot pressure (in the tube) is factory set full open & can only be adjusted down (less). Also check the gas **** didn't get closed or turned half way.? Assuming its not the t-couple. If all is good & it still won't stay on. Replace the gas value.!
Sep 20, 2011 | Heating & Cooling
I have a canon ir 400n series. the white plastic part tht hold the magnet for the door broke off and now the magnet will not stay in, resulting in the door not closing - and LOTS OF TAPE FOR US TO TRY TO...
here is a easy fix..... take the magnet from the other side and put it in it's place..... one side of the door really needs the magnet to hold the door closed..... Good Luck
Jul 29, 2011 | Canon imageRUNNER 400S Copier
The digital control panel is on the fritz,
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down--and none of the buttons were functional.
My husband took the cover off and found that a magnet is what keeps the lever down when the toaster's on, and allows it to go back up when the toasting is done. It's an electro magnet that works only when the toaster is on. It seems that when I turned the unit upside down and rightside up again, crumbs landed on the magnet's contact plates (which are about 1/4" x 1/2") and would not allow the magnet to engage. Because the magnet wouldn't engage, the lever would not stay down, and the toaster shut off. Brush off the magnets, replace the cover and toast away!
Nov 28, 2008 | Oster 6330 4-Slice Toaster
Toaster won't stay down but does heat
I had the same problem. I opened up the toaster and found that the electromagnet that holds the plastic clip to keep the toaster down had a tiny crumb between the magnet and the metal plate. I cleaned the magnet and it is working fine again. We spent 6 months burning toast by holding it down with a chopstick wedged between the lever and finally took a shot before I went to buy a new one. Took me all of 15 minutes.
Jul 08, 2008 | Breville CT20 Retro Classic 2-Slice...
Bread won't toast
We ran into the same problem today with our toaster. There was never a problem before I cleaned it--not only by sliding out the crumb drawer, but by turning it upside down to dislodge every last crumb. After that, It would not stay down when pushed down.
Dec 27, 2007 | Kitchen Appliances - Others
Toaster lever
I have sunbeam model AGW toaster level is not staying down and no power. the spring work, i want to know what part hold it down. please help or there any repair company i can take it (s. california) thanks
Dec 17, 2007 | Kenmore KTES4 4-Slice Toaster
Lever on taoster will not stay down
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Oct 30, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Bodum Bistro Toaster Logo
Top Bodum Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bodum Kitchen Appliances - Other Expert? Answer questions, earn points and help others
