Question about Magnavox ZV427MG9 DVD Recorder VCR
Vcr will not play
When a tape is loaded into the vcr and PLAY is pressed the vcr will play for approx. 17 to 20 seconds then automatically shuts off. When the unit is turned back on the tape is ejected. When the tape is loaded back in and Play is press, the same results occur. Under General Settings, Reset to factory settings was press several times with no effect. The unit has been unplugged and plugged back in with no effect. I own two units and this occurred on one about 12 months after purchase and the other about 18 months after purchase. Now neither unit an play VCR tapes.
2 Suggested Answers
atang1
  • 734 Answers
SOURCE: Magnavox ZV427MG9 DVD Recorder VCR Combo plays vcr for about 5 second then stops and shut off, when turned back on it ejects the tape.
This combo has a problem with the vcr unit which take up wheel will stop working and spill the tape. the unit will stop and eject the tape. You have to replace the whole vcr assembly.
Posted on Feb 21, 2012
After a long period of non-use,of my VCR, I recently tried to play a new VHS tape. It loaded properly, but refused to play it.
Could be the belts have become too old for the unit to function. you could try to take the unit apart to clean them.
Mar 25, 2015 | JVC Hr-a591u 4 Head S-vhs Hi-fi Stereo Vcr...
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
Why does the jvc hr-s3800u shut off after about 8 seconds of tape play
It could be a tape end sensor problem, take up reel is not working, or a idler assembly issue.
Mar 20, 2012 | JVC HR-S3600 VCR
VCR shuts down when tape loaded, "play" pressed...
could be dirty play heads and or rollers, run a wet cleaner through and see if this cures the problem.
Apr 08, 2010 | Philips Magnavox DVD/VCR Dual Player
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
Will not record or play back VHS for more than 30 seconds
I can tell you some ideas genericaly for VCR's.
This could be an idler wheel assembly problem, or a tape tension, or a reel torque problem.
It can also be a power supply problem where the supply is working just on the edge. Due to some worn components in the supply it can be partialy shutting down.
Your machine will have to be checked out by an experienced VCR tech.
Jerry G.
Dec 04, 2008 | Radio Shack Accurian ADR-0106
My vcr won't play.
Sounds like a bad belt or the tape isnt loading into case correcly bad rubber idler assy.
Oct 23, 2008 | Quasar VHQ400 VHS VCR
TV keeps shutting off after 10 seconds
It's possible from what you described that your center LED or prisim was broken when the tape was extracted. Like many others these units depend on a series of startup checks and one being the tape path. On the play table of the VCR is a center prisim/LED and two light sensitive diodes on either side of the tape loading assembly. If these diodes do not detect the infared beam the unit will go into shutdown. I'd check there and let me know. Bill
Jun 03, 2007 | Sylvania 6319CC 19 in. TV/VCR Combo
The unit will fast forward and rewind, but won't play
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. Check all the belts above and below the deck. Belts can appear to be firm but if they do not return immediately to their relaxed length when you stretch them 25%, they will need to be replaced. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but
Nov 22, 2005 | Sharp VC-H810U VHS VCR
Magnavox ZV427MG9 DVD Recorder  VCR Logo
22 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
