Question about Jenn-Air 30 in. CCG2423 Gas Cooktop
How to remove temperature knobs on stovetop - Jenn-Air 30 in. CCG2423 Gas Cooktop
Can't find replacement burner knobs for my PGL985UC Bosch stovetop gas stove
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Mar 21, 2011 | Bosch PGL985UC 36 in. Gas Cooktop
PILOT LIGHT OUT. sTOVETOP CONTINOUSLY MAKES A CLICKING SOUND. i BELIEVE THE PILOT IS OUT. hOW DO i REIGNITE THE PILOT AND MAKE THE CLICKING STOP
Sorry to read about your problem, I hope this helps you out.
Their is no pilot lite on your oven..the clicking you hear is the electronic pilot system..
you have a defective control knob...
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | GE Cooktops
GE gas stovetop burner doesn't light
there are sparker modules on each burner behind the button, it may be that yours is failed, if you turn on other knob and you see spark at problem burner and still isn't lighting you have to make sure the black or grey tops are paced on perfectly, just give them a little nudge and you have to make sure area is perfectly clean for spark to take effect, spark will go for cleanest area on metal. so ensure area is clean and check burner top
Feb 05, 2010 | GE 30 in. Profile JGP979 Gas Cooktop
Elements not working properly
hi gud day,the swicth knob u nid is repairable but is hard to repair no nid to buy a new one.the to open the unit to know how to remove the switch then try to study to repair or clean it coz other swicth is not work properly if we have dust or any dirt inside the swicth.
tnx gerbee
May 26, 2009 | Maytag MEC5430BDS Electric Cooktop
Recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Feb 28, 2009 | DCS Cooktops
My Viking VECU105 electric cooktop has one burner which will not regulate the temperature. It can be turned on and off with the control knob, but after that, there is no temperature control. Any ideas on...
It will need either a dual infinite or infinite switch, If the burner has an inner an outer element then it requires the dual.
Firstly turn power off at breaker.
The unit needs to be removed from the cut out and the cover removed from below the swtichs. the knob taken off and the secureing screws removed, then take note of the layout of the wiring and the poistion of the switch, then swap the wires, reassemble test and then re-install
Feb 18, 2009 | Viking 31 in. VECU105 Electric Cooktop
Electric stovetop disconnection
Can you provide specific model number information ? That would help me to help you...
Sep 13, 2008 | Cooktops
Jenn-Air 30 in. CCG2423 Gas Cooktop Logo
61 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
