Question about Shure ULXP4 Receiver
CODE EOOO COMES UP ON MY DISPLAY. IHAVE A SHURE SM58;MODEL ULX2-J1
CODE EOOO COMES ON MY DISPLAY. I HAVE A SHURE SM58 MIC. MODEL NUMBER IS ULX2-J1. NO SOUND IS COMING FROM THE MIC
night71
  • 328 Answers
SOURCE: feedback
That is a great mic. It has a lot to do with the room your in and acoustics of it. If you are too close to your PA or monitor, it will also feedback. Lowering treble and reverb will also help.
Posted on Nov 04, 2007
  • 4234 Answers
SOURCE: the mute / off switch
Yes it is relatively easy. First try to get the part from Shure. If you are not comfortable repairing this, check with a local shop and ask how much they would charge you. A replacement mic should not cost any more than about $95 so be careful no to spend too much for the repair. You can also check with Shure on their repair cost.
Dan
Posted on Nov 07, 2008
  • 3 Answers
SOURCE: shure sm58 mic does not have full power
You should consider a microphone with more power to get the volume you need. I can personally recommend the CAD C195 Cardoid Condensor microphone. It has great output. The only downsidefor most people is that they don't have phantom power. This is what gives the mic its boost. In order to get the most out of any micrphone, you need to have a preamp, an equilizer, and an output. The output is your PA system that drumbanger mentioned.
But since you are using a Peavey, here is my strong recommendation. Get a mini preamp, and hook it up to your Peavey. You can use a Behringer 2mic mixing board for your preamp. It's small, and it can sit right on top of the Peavey.
XENYX 1002
http://pro-audio.musiciansfriend.com/product/Behringer-Xenyx-502-Mixer?sku=631262
CAD C195
http://pro-audio.musiciansfriend.com/product/CAD-C195-Cardioid-Electret-Condenser-Microphone?sku=270775
The reason why I suggest the two-mic XENYX 802 and not the 1 channel 502, is that the 1 channel doesn't have phantom power.
In order to connect the XENYX to your Peavey, this is all you need. You can get one at radio shack for pretty cheap.
http://accessories.musiciansfriend.com/product/Mogami-Pure-Patch-RCA-to-14-Mono-HiDefinition-Patch-Cable?sku=339031
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: i have a shure sm58 wireless microphone when i
Unfortunately the sm58 capsule is very hard to get apart without damaging the contact surface.
You would have to take the contact side apart 1rst
bend all the little tabs away which hold the brass plated disk in place
then its a matter of edging the disk out....CAREFULL any scratch is bad!
Once you have the disk out you will need a 1/4" socket to remove the shaft bolt,
unsolder the green and yellow wires taking note where they were soldered.
Then the element can be pulled out.
What to after that, I'll let that up to you.
Be wary, you will void warranty.
Posted on Jun 30, 2009
  • 1138 Answers
SOURCE: i have a shure ulx2-j1 transmitter the two wires
You will need to obtain a wiring diagram from the Shure site. Try here:http://www.shure.com/ProAudio/TechLibrary/index.htm The cartridge body of the mike screws on to the main body. The XLR jack can be removed by turning the flat headed screw clockwise through the access hole on the side of the mike at the bottom of the body. The windscreen also screws off the cartridge body on the mike but won't help you to access the wiring. Unless it is the wiring from the cartridge to the body or the wiring from the body to the jack you are better off having it professionally serviced.
Posted on Oct 23, 2009
CAN'T GET MY SHURE M58 TO SYNC
Check to make certain the mic and the receiver are on the same frequency range. The frequency range will be provided on a sticker on the mic and the receiver.
Feb 10, 2014 | Shure ULX P4 BETA 58A Professional...
Is sm58 wireless mic compatible t4a receiver-shure
The "SM58" is just the cartridge on the top. It would depend on the model of handheld transmitter. The model number is on a sticker in the battery compartment.
Nov 07, 2012 | Shure SLX24/58 Wireless Microphone System...
How do you get a shure ut4 diversity receiver to work with or receive a wireless sm58 Shure mic?
"SM58" is just the cartridge. You need to look at the model number inside the battery compartment. The UT4 receiver will only work with a UT2 transmitter. They must both be on the same exact frequency.
May 22, 2012 | Audio Players & Recorders
Shure SM58 not working. Tried on various pieces of equipment using various configurations of cables and not a sound. Took unit apart and all wiring appears to be intact. The mic has been unused for several...
The SM58 is a dynamic mic. It's actually a very simple device. Thus, it doesn't "degrade". If an SM58 fails, it usually fails catastrophically. Now, the problem for is that you don't know if the failure is in the handle (which includes a transformer) or the cartridge).
You can order a replacement cartridge from Shure and solder it in place, but might be better for you to just send the mic to Shure. I believe they will just replace the mic with a new one for their service fee.
www.shure.com/service
Nov 20, 2010 | Shure SM58 Professional Microphone
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
Apr 12, 2010 | Shure SM58 Professional Microphone
Shure sm58 just started outputting very low volume. It has been working fine with our system for years. Tried other sm58 mics on the same mic cable with same system setup and no troubles. There is still...
Check your wire connections inside the mic where the xlr cable connects to the mic. Hopefully your mic has never been dropped as this will damage it. The sm58 is pretty much indestructible, so check your cabling that you use, try a different channel.
Apr 04, 2010 | Shure SM58 Professional Microphone
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Jan 05, 2010 | Shure (LX287CC) Professional Microphone
Shure ULXP4 Receiver Logo
19 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
