Question about JBL Charge Portable Wireless Bluetooth Speaker Gray
Blue blinking light
Blue light blinking and it won't connect to my Mac Pro
My computer monitor wont start up
try pulling out the power plug to the monitor and then plug back in and turn on monitor.
I am assuming you plugged the DVI cable back in to the correct port on the monitor and Mac Pro.
May 03, 2016 | Computers & Internet
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Just purchased an Optoma PK -201 pico projector. I cannot get it to display anything from my Mac Book Pro. Just bought the VGA cable and I have the screen resolution set correctly. When I plug the...
I had this same problem too. You have to reboot your mac. Either that or the cable you got for it is wrong. Some cables on ebay look identical to the ones that work, but they don't work. Give the rebooting a try and make sure all the cables are tight, especially the dvi to hdmi converter cable.
Feb 20, 2011 | Computers & Internet
The blue light on my Maxtor is blinking really fast and my Mac no longer recognizes the connection. How can I fix this?
Have you tried restarting your Mac (with the Drive still connected)?
Otherwise try:
1. Disconnect the USB cable from your Mac.
2. Restart your Mac.
3. Reconnect the USB cable to a different USB port on your Mac (like the keyboard USB port for example).
See how you get on. Let me know. Regards,
Feb 16, 2010 | Maxtor OneTouch II 300 GB Hard Drive
Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
Pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
Jul 13, 2009 | Radio Communications
My dymo is printing but the blue light won't stop blinking?
I have a LabelWriter 4XL with legit labels and driver on Mac. I had a flashing blue light. I had tried cleaning, cycling power, reseating the interface connection and it seemed none of this helped. Then I removed the labels from the feed and re-fed them and the error cleared.
Jun 06, 2009 | Dymo LabelWriter Thermal Printer
JBL Charge Portable Wireless Bluetooth Speaker Gray Logo
Top JBL Car Audio & Video Experts
hoyzee1
Rob Beech
Mark Skinner
Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
