Question about Speed Queen AWS52NW Top Load Washer
Washer leaking somewhere around the top inside
04 Mustang V6: The convertable top is leaking somewhere which causes water to pool behind drivers seat. Where should I start?
The best way to find this leak is to use a waterhose, make sure inside is dry them start a slow water spary at the front window and only front glass it is better to have someone inside with a light looking to see a stream coming in, after a while and no leak found start moving up to the top and work your way to rear glass but do this slowly to pinpoint the leak the preson inside must look around also.
Aug 22, 2010 | Ford Mustang Cars & Trucks
My washer fills up, but not inside the machine. If I put the machine on spin, the water drains out. Why won't it fill inside the machine?
The water is going into the machine, but somewhere below the inside drum. I can hear it sloshing around if I move the inside drum. If I put it on the spin cycle, it does not spin, but the water comes out of the hose and into the sink.
Nov 09, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
My machine is leaking from the bottom of the machine. Hoses in the back are ok. but i'm afraid to run it
you will have to open the top of the washer.
take a flat head screwdriver and place it at the seam area around the washing machines rim, the front should lift up from some clips that hold it down, look down inside for any corroded hoses or signs of water leaking from pressed hose fittings.
if there is no leak signs at top of washer then you may have to take the back cover off and look at the bottom for signs of water stains or corrosion.
replace hose if tightning it doesn't work. run the washer with panel off so you can spot leaks.
Sep 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Thick Gear-like oil leaking from the bottom somewhere
looks like your washer is developing a leak from the seals in the drum thus allowing some water to seep into the bearings get it checked before the bearings run out completely
Jul 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Small amount of water from washer
ck around pump at place motor shaft connects ..that is mot likely place
Sep 12, 2008 | Kenmore 24032\24036 Top Load Washer
Oil leaked into the washing machine tub.
there is no green oil in washer ..ck/detergent/fabric softner bottle close for leaks oil leak would usually be brown or almost black in color ck around top edge of washer tub for deposits of softner/detergent
Jun 17, 2008 | GE WBSR3140DW Top Load Washer
Top loader
I would check around the door seal see if there is a hole in it, it will probably be around the side somewhere.
Nov 18, 2007 | Hotpoint WMA50 Front Load Washer
Amana Top Load Washer model# LW3502W Washer leaks water somewhere between wash & rinse cycle best I can tell...drain hose checks out fine. At beginning of wash cycle the first minute or two of agitation...
Sounds like the water seal is damaged and the leaking water has damaged the top bearing which is just below the water seal. You will need to have the hub & seal kit replaced.
Oct 30, 2007 | Amana ALW480DA Top Load Washer
Amana LWA50AW Washer Leaks!
you need to get the front off... grap a light and get down and look inside to find out whats leaking... with out looking its just guessing check all water hose connections, water pump, and main seal where transmission goes thu drum
Sep 05, 2007 | Amana LWA40A
Speed Queen AWS52NW Top Load Washer Logo
12 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
