Question about Sharp 60" Aquos LED Smart TV - LC60LE640U
60 " sharp aquos smart tv LC60LE650U white light blinks 5 times then 2 times
satavlad
  • 405 Answers
SOURCE: the power light on my sharp aquos blinks green and
TV detected lamp error, problem could be either INVERTER UNIT or one of the lamps. Defective part has to be replaced, lamp error counter reset.
Posted on Nov 13, 2009
SOURCE: Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Posted on Sep 07, 2008
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
  • 148 Answers
SOURCE: Sharp Aquos LC30HV4U stopped working
You are in luck!..The units poowerboard is overheating and since you have it taken apart already this is the fix for you!...Check the popped capacitors in the metal box you find on the back of the actual screen inside the unit...This is a very common problem,m so I've helped many this way and wrote a general post on the how to's of diagnosing and repairing the problem, follow these steps and your tv ill be good as new for less than $5.00 before feb 5 th!! :P...Here it goes (please rate if this works out :D).....................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped anyone (or not) then please rate, thank you!
Posted on Feb 03, 2010
  • 8457 Answers
SOURCE: Aquos model LC46D64U...approx 2 years old..Won't
I have a Sharp LCD 46 in.tv do this often.Yes,it is.This problems,the tv Tuner signal board have problem,but the tv is still useable.The POWER and OPC light indications flashes.Just push the power switch again,wait see tv turn,not POWER and OPC flashes again,push the power switch agian and wait.Have to do this like 3 or 4 times sometimes,than the tv backlight will come on,tv will work.Don't know but,if u require to pushing power button more 10 or 12 times,the tv Tuner signal board don't take an turn on the tv backlight get the tv to work.The Tuner signal board is dead,time to replaced the tv Tuner signal board.
Posted on Oct 18, 2010
Sharp LC70le650u dead set, error code, 2 sloww flashes 5 fast. I have done a reset twice
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 07, 2016 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
TV will not come on, white light center bottom of tv flashes twice then 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 26, 2015 | Sharp 70" LC-70LE757U AQUOS Full HD Smart...
Does this tv have an option to set a timer to turn it on?
spec sheet here
http://files.sharp.ca/Downloads/ForHome/HomeEntertainment/LCDTVs/SpecSheets/LE650_SERIES/LE650%20Series_Spec_Sheet_rev.pdf
It does have a Sleep Timer as most do. Not many people want the television to switch on when they are not at home?
Direct Button Operation
INPUT .......................................................... 20
Changing Channels ...................................... 20
Changing Volume ......................................... 20
MUTE........................................................... 20
Sleep Timer .................................................. 20
manual is here
http://files.sharpusa.com/Downloads/ForHome/HomeEntertainment/LCDTVs/Manuals/mon_man_LC70LE640U_LC60LE640U_LC52LE640U_LC70C6400U_LC60C6400U_LC52C6400U_LC80LE633U.pdf
Sep 22, 2015 | Sharp AQUOS 60" 650 Series LED HDTV -...
Sharp LC-60LE632U -- White LED light up front blinks but TV will not turn on
Dec 21, 2014 | Sharp AQUOS LC-60LE632U 60" LED TV...
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
60' Sharp Aquos tv power bar flashing but TV wont turn on. Any help??
Good day!!!
please try to count the exact number of blinking lights to diagnose where the fault came from..
Also try to open the cover and look for any bulged capacitors on power supply board..
Dec 04, 2011 | Sharp LC60LE810UN 60 in. LCD TV
Sharp Aquos wont turn on
this is either a power problem or the screen needs re-gasing
Jan 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 60" Aquos LED Smart TV - LC60LE640U Logo
421 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
