Question about AudioBahn Car Audio & Video
No spark on a 1995 honda trx 90 - AudioBahn Car Audio & Video
5 Suggested Answers
  • 8404 Answers
SOURCE: Need a free online manual for working on a Honda
Look here ... http://hrca.honda.com/
Posted on May 06, 2010
SOURCE: 1985 Honda trx 125 no power at coil wires & no
I have a 85 trx 125 it ran great, parked it then the kids went to start it and it wouldn't start. I checked for spark, has it but seems weak to me, changed plug and still same problem. Any ideas? Coil?
Posted on Mar 11, 2011
  • 3567 Answers
SOURCE: 85 Honda trx 125 ran great when parked, kids tried
Start with a fresh spark plug. Part of the spark may be traveling to ground via the carbon deposit on the ceramic electrode insulator. Drain the carb; condensation in the gas tank may have built up in the carb float bowl. Engines don't run well with water as fuel. While servicing the bike, clean the air filter and lube the cables.
Posted on Mar 12, 2011
gregg201
  • 40748 Answers
SOURCE: 1985 Honda TRX. Why does it crank and run for a few minutes, then die?
Hi, David the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or a damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture ***** improperly adjusted.
10. Water or dirt in the fuel system, carburetor or filter.
11. Restricted, blocked or kinked fuel line.
12. Fuel tank empty.
13. Gas cap is not venting properly or fuel tank venting system blocked.
14. A failed fuel pump, pressure regulator and or fuel injectors.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please visit the websites below. Good luck and have a nice day.
1985 TRX 250 Stalls when you put it in gear
http://www.pavementsucks.com/threads/1985-honda-foreman-350-stalling-problems.17133
http://www.trx450r.org/forum/93-engine/202679-04-trx450-idles-but-dies-throttle.html
Honda TRX 350 Owner Manual
https://www.tradebit.com/filesharing.php/search/0/1985+honda+trx
Posted on Mar 13, 2016
Honda trx350fw will not start i have spark and fuel still nothing
There only three things a good engine needs to have to run:
1. Adequate compression
2. A properly timed spark
3. The proper air/gas ratio - delivered
.. one of these is missing...
Jul 24, 2017 | Honda 2005 TRX 400EX
Honda fourtrax 4x4: will a 1995 stator/pulse gen. work on a 1993
Yes it will. They are the same as long as it's the same size engine.
Oct 19, 2016 | Honda 2005 TRX 400EX
1994 honda 4trax no spark
Hi, Jdebord if you have a CKP sensor it needs compression to send the correct signal to the ICM/ECM, make sure both spark plugs are in heads and use a grounded third plug to check for spark or hold spark plug cable close to spark plug in the head. If still not getting spark the usual suspects are:
1. Fouled spark plugs.
2. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Loose connection at ignition coil or plug between ignition sensor and module.
4. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
5. Faulty ignition coil or ignition / electronic module
6. Failed CKP, CMP, or BAS sensor.
7. Faulty ignition switch.
8. Security alarm failing to disarm needs reset
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Honda TRX 70 No spark fix try this FIRST
5 25 15 1984 Honda TRX200 no spark opened Stator
Honda FOURTRAX TRX300 TRX300FW 4X4 1988 1994 Online Service Manual
http://www.bikebandit.com/oem-parts/1994-honda-fourtrax-300-trx300/o/m151537
http://hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/TRX300-1995.pdf
Dec 01, 2015 | Honda Motorcycles
Where is the vr on a 2007 honda trx 90
There is no vr on the trx90. They have an alternator. Please see pic
Jun 13, 2014 | Honda 2007 TRX 90
Can i use a bigger pilot jet with factory main jet
Pull the spark plug and see what it looks like with the original jet. it should be light brown and not covered with goo. If it is then the 40 is too big, If you change it out, drive it a while and check the plug again. The jet size is dependent on altitude and a smaller jet is better at high altitude so that you dont run rich.
Jun 05, 2014 | Honda 2006 TRX 90
1985 Honda trx 125 no power at coil wires & no spark at plug
Hi, Sounds like you may have a faulty rectifier. Should not be too expensive to replace.
Apr 09, 2010 | 2002 Honda CR 125 R
Car Audio & Video Logo
21 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
