Question about Vacuums
How to replace belt eureka vacuum endeavor nls
  • 10 Answers
SOURCE: smoking belt
Belt is slipping because the bearings on the beater brushes, which it turns, are jammed or full of dust.
Alternatively the belt has stretched after being overheated and needs replacing because it now slips.
Posted on Dec 31, 2007
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
  • 3 Answers
SOURCE: I want to replace the belt on an upright eureka
I just replaced the belt on my 4481. Very simple. Be sure unit is unplugged. Unlock handle and let it lay down. Remove two screws on plastic cover. I purchased my belt at target for 2.54. Part number anywhere is Eureka U. Remove the roller brush. Loop belt around drive motor first and then around roller brush inserting the roller back into place belt side first. Replace cover and your ready to go. 10 min fix.
Posted on Sep 04, 2009
  • 69 Answers
SOURCE: new eureka vacuum has not real suction
Is the belt slipping. Are all the seals good
Posted on Mar 27, 2010
  • 128 Answers
SOURCE: the belt broke on my vacuum
Remove the base plate. It is held with screws accessible from under the unit.
Inside you will see the beater bar and the belt.
Remove the beater bar. This is self explanatory once you see inside the power head.
Remove the old belt.
Find a replacement from your local dealer or online.
Replacement is the reverse of removal.
This is a simple job you only need a screwdriver.
Good luck, please rate this answer. Thanks.
Posted on Mar 30, 2010
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
Need a belt eureka 4386 whirlwind
Hi, It's Jim with Crucial Vacuum,
If you're looking for a replacement belt for your Eureka 4386 then we've got you covered. We carry a variety of high-quality replacement parts for a multitude of vacuum brands including Eureka.
You can purchase direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka-style-u-belt-2pk.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Feb 25, 2015 | Eureka Vacuums
My Eureka endeavor nls vacume cleaner will not suck at all. I have taken it apart to clean everything but still nothing what could be wrong with it
HI, it's Jim from Crucial Vacuum!
Vacuum maintenance is a general procedure and requirement for all units to ensure suction. Your Eureka can be easily maintained and by doing so properly you will make sure your unit performs at it's peak performance. The following tips will help your vacuums suction.
After every use, make sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged.
It is recommended to wash and clean your unit's filter screen weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
Foam and cloth filters should also be washed and dried weekly, by following the same steps from cleaning the filter screen. Do not use any soap, dishwasher, dryer or washing machine to do so. Allow your filters to air dry for 24 hours before re-installing them in your Eureka.
Replace your HEPA filter and belts every 6 months. Last, make sure to clear your roller brush of any tangles hair strands or debris monthly and to replace at least every year.
You can purchase direct your Eureka replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/eureka.html?limit=all
Jim Thompson
Nov 05, 2014 | Vacuums
Eureka Air Excel compact will not turn on
Take it to your local vacuum cleaner repair shop for diagnosis.
Oct 30, 2014 | Eureka AirExcel Compact NLS Canister...
Eureka 431BX Bagless Upright Vacuum: i would like to know how to replace and if there is a specific type of belt to use?
Here is a link to the exact belt you need to replace (the belt should be replaced yearly for optimum performance) and a manual you can view which has instructions.
Eureka 431BX Replacement Belt
Owner's Guide (1.1 MB download)
Dec 07, 2009 | Eureka 431BX Bagless Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
