Question about Refrigerators
Changing the light bulb on my LG fridge Freezer GRB207TUJA
SOURCE: Fridge and Freezer not cold, compressor not coming on
these are 2 different things.check the light switch. also check cold-control, defrost timer, relay on compressor.
Posted on Jul 22, 2008
  • 833 Answers
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Posted on Nov 12, 2008
SOURCE: Where is the filter located
We have this model and the filter is attached to the water line tubes on the outside of the machine. My husband layed ours ontop of the unit but it would depend on who installed it. If you can locate the outer tubes you should be able to find the filter.
Posted on May 02, 2009
SOURCE: The lights do not turn on when opening the doors despite changing the bulbs.
It sounds like the door switch. Check to see if it is sticking -- it should come out when the door is open. If it's not sticking, the switch probably needs replacing.
kel1guy2002
  • 3740 Answers
SOURCE: LG refrigerator GR-B258jvc - replacing light bulb
There are usually 3 or 4 locking tabs on the cover that just need to be pressed INDIVIDUALLY toward the bulb to release them and then carefully remove the cover. The ones with 3 tabs usually have and upper and lower tab then the thrid tab is on the side. Removed the upper and lower tabs by pressing inward to the bulb and then the cover will pivot out on the 3rd SIDE tab.
Thanks for using FixYa.
Kelly
Posted on Apr 09, 2010
I have an LG American fridge freezer GRB207TUJA which the edge where the doors close on is very very hot
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 25, 2016 | LG Refrigerators
I have an LG fridge freezer grb207tuja but the fridge is freezing everything. Anyone know what to do? Thanks.
if you have a temp control change it. make sure you are going in the correct direction with the dial. if it is on the door, change it. check your owner's manual too.
Mar 05, 2015 | LG Refrigerators
Removing LG refrigerator control panel
Put your model number into a repairclinic.com or go to YouTube.com there should be a video on either site showing you how to remove that panel
Mar 02, 2014 | Refrigerators
My sub zero 690 has the fridge & freezer light out as well as the screen
Well the most likely cause is 2 bad door switches, though I rarely see the door switch go bad in the freezer. At the top of the door openings you will see 2 switches in the freezer and the fridge. If you pull down the grille and remove the cover over those switches, the light switch will be the one with the white back, and the fan switch will be the one with the black back. I would try changing the switch in the fridge, and maybe start in the freezer by changing at least 1 bulb before blaming the switch. If that 1 new bulb doesn't light, change that switch too.
Mar 24, 2013 | Sub-Zero 690 Side by Side Refrigerator
LG Fridge-Freezer model no. GR-T632DVQ The upper freezer lights works. The lower fridge light stopped working. When tested the light bulb works and is NOT broken. There is a combination double...
looking for a door for lg refrigerator GR-T632DVQ
if anyone can help me plz ring 0421203100
perfect fridge, had it for 10 years, door fell off today :(
i've been searching everywhere, *sigh
please help if u can
Mar 16, 2011 | Refrigerators
We have a Lg LFC25760SW fridge and the lights stay on in side the fridge
LG had a circuit board malfunction with many french door models with fridge lights staying on with the door closed. the bulb lens usually overheats; deforms; and falls off. the plastic frame surround is warped too. the bulb sockets are darkened too. if this is the case, call LG and they will usually repair this overheating issue for free. you can just unscrew the bulbs for the meantime.
Jun 15, 2010 | LG LFC25760TT Titanium Bottom Freezer...
Nov 12, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
