Question about Marantz Audio Players & Recorders
NO disc displayed on player...
Displays no disc and won't play CD BUT will play IPOD in USB port
techman
  • 3130 Answers
SOURCE: Disc gets jammed mid-way between CD magazine slot and inside player
Thats alot of disc this ubit holds. 110+1!! The CD changer arm mechanism sounds like is out of timming or the gears have slipped there teeth, and or the cam is broken, or theres a couple of small microswitches that can get broken as well.. The only way to work on this unit and see what the problem is, is to get a service manual and go through the mechanical alighnment and see where the problem is. Unless you can do a physical examination and know where every lob and gear is suppose to be, I do not see any other ways.
Posted on Oct 06, 2006
robotek
  • 1512 Answers
SOURCE: DENON DN-C615 DISPLAYS "SERVO ON"
The owners manual references turning the servo on and off on page 8
mpro
.com/users/getdownload.asp?DownloadID=92" spwrap?>mpro.com/users/getdownload.asp?DownloadID=92">http://www.d-mpro.com/users/getdownload.asp?DownloadID=92
Good luck... Happy to help you further if things get complicated. A "FixYa" rating for this would help my profile. Thanks
Posted on Feb 12, 2008
SOURCE: c-314 stanton cd player, reads no disc, but disc is in cd player
as with my other posting - all i could do was mail it to be fixed. then it stopped working again so perhaps its time to go elsewhere.
Posted on Oct 13, 2008
  • 85 Answers
SOURCE: Pioneer PD-F805 can`t read discs.
Few things either cd,s are not compatible
laser has died or laser ribbon cable is broken
Posted on Jan 08, 2009
  • 86 Answers
SOURCE: Sharp XL-HP515 CD Player won't play. Displays "toc read"
take it apart and clean len with a qtip an rubbing achol on face and mirror sides(top and under
Posted on Oct 09, 2009
Player won't load a blank DVD-RW disc
because there is nothing to read in blank cd rw , because dvd operating system is not meant to write cd ,but only to read the disk
Jan 31, 2013 | Samsung DVDR120 DVD Recorder
My kicker iPod docking station displays aux-in and won't play the iPod there is nothing plugged into the aux jack point
Turn rotary control counter clockwise to disable auxiliary input. When auxiliary input is disabled , menu will display "--".
Jun 30, 2012 | Kicker IK150 Digital Docking System w...
Displays no disc when Cd is player
Hello
Put it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.
The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
Jan 23, 2012 | Sanyo DC-DA1000 CD Shelf System
Sony slv-d370p displays dvd_errlog5 message
You`ll find the error codes in the service manual, But I don`t think this will help you, it sounds like you have a compatability problem. Are you not better connecting your turntable up to your PC?? You can purchase these really cheaply out of ASDA and other good retailers now which will plug directly into the USB port. You`ll have no problems then, I promise, I`ve done it. Ian
Has it actually wrote to the disc and have you finalized the disc?? Does the disc look like it`s been wrote to, you can usually see the recorded section of the disc but if it`s not been finalized, It`ll never play on a normal CD player. A CD player requires the TOC (Table Of Contents) in the centre of the disc, if this is missing, the CD will just give up and say disc error or something similar. Ian
hope this helps,thank you
Feb 10, 2011 | Sony SLV-D370P DVD Player/VCR
THE PLAYER DISPLAYS BAD DISC.
You have not said the TYPE of CD or DVD you are trying to play.
Your manual will clearly state what can be played and what cannot. ALSO, some mfg's like mine (samsung blu-ray) provided software or firmware updates you can d/l to flash drive or burn on cd and insert.
Check manual and your mfg websit for what's available.
May 20, 2009 | Cyberhome CH-DVD 300 DVD Player
Error Code Displayed When CD Inserted
Error 01 is normally on most machines to say it cannot read the discs. Could be dirty laser or a defective one. Must open to make better diagnosis.
May 12, 2009 | Jensen MSR4050G CD Player
CD Alarm Clock displays NO DISC when attempting to play a CD.
try cleaning the lense using a cd lense cleaning kit/cd. this usualy helps. if it doesnt work, repost
Dec 18, 2008 | Memorex Audio Players & Recorders
Check disc
Change your DVD player
May 23, 2007 | LG DE9523P DVD Player
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
