Question about Viking VCSB423 Side by Side Refrigerator
Temperature buttons not working
The "higher" button is not working.
Flames won't come on when oven temperature is set on 250 and higher
If the flames are coming on when setting the temperature to less then 250 then you have a problem with the thermostat or the button that setting the temperature.
Oct 13, 2012 | Ovens
2002 Toyota Camry power door lock failure in higher temperature
look in the fuse box which is under the dash or in the engine compartment drivers side for the voltage relay fuse possibly square that powers the door motors and door locks . corrosion around relay or just bad relay replace and try power key lock release again and see if that works or first go into each door at a time and probe wire that leads to each door lock actuator motor and if you are getting proper current with helper pressing key to activate motor and proper current is displayed start replacing motors if intermittent wrong current or no current at each door checking with home meeter probing motor wire while helper is pressing key fob relay is bad and needs to be replaced. That is all i got good luck ps if all fails from that point replace key fob controler
Jun 13, 2017 | Cars & Trucks
Purchsed a Zhida Temperature Humidity/Calendar and do not have the instructions, Need help
to adjust it just hold the button clock for a long time and then you press once a time the clock button to move to hour, time, date and even the day so press the 12/24 button to adjust it (lower or higher).
Aug 25, 2011 | Office Equipment & Supplies
Our Wedgewood stove suddenly started acting up. We have to use the Reset button often to get any oven lighting at all. The pilots are fine. The broiler (separate compartment) is fine. But the oven lights...
It sounds like the problem is either the safety valve (the reset button) or the oven thermostat (the assembly behind the oven temperature knob). Both parts can be rebuilt (if they are original parts) and replacement parts are still made for 1940's and 50's Wedgewoods.
Mar 19, 2011 | Stoves Kitchen Ranges
I have a rs730 but do not know how to set the temperature on the remote or check car temp!
With the built in temperature sensor you can monitor, Through the LCD screen, the present indoor temperature of the passenger compartment of your vehicle. Press and hold the transmitter "F" button first until 3 chirps are heard. Then press the F Button three more times so that TEMP appears on the remote. Within 3 seconds press button; the in-door temperature will be shown on the LCD screen. This reading may be higher than actual ambient temperature due to the greenhouse effect and is relative onlyto the inside vehicle temperature.
Dec 21, 2010 | C3RS730 LCD
Fridge side wont cool properly.
Check out this link below for a PDF manual on your item. Great information to have. Just copy and paste into your browser.
http://www.samsung.com/us/function/search/espsearchResult.do?keywords=RS2630SH&input_keyword=RS2630SH
Try this:
Temperature Adjustment
• After 24 hours, adjust the controls as needed. Adjust temperature gradually: push the button in small increments,
allowing the temperature to stabilize.
• Press the button(Freezer Temp or Fridge Temp) repeatedly until the desired set temper.
• For lower temperature, press the button(Freezer Temp or Fridge Temp) towards coldest.
• For higher temperature, press the button(Freezer Temp or Fridge Temp) towards cold.
If this does not work for you let me know or you can contact Samsung support at 1-800-SAMSUNG (1-800-726-7864) Mon - Sun : 9am - 9pm (EST).
Or you can try this Live chat at this link below, just look to the middle left of their page for live chat:
http://www.samsung.com/us/info/contactus.html
Let me know how this works for you or if I can help you with anything else.
JimmyC
Oct 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Oven model RBS245pd86
after cleaning the oven the bake temp would not go any higher than 350. when you press the temp button to go lower or higher it only go down. could you tell me what is wrong or what to do.
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
Information
Chooses the temperature.
Being general, usually the higher the number the higher the temperature.
Check your garment for the correct temperature and the instructions for iron for the exact temperatures represented.
Hope it helps
R.
Jan 01, 2008 | Irons
Oven Temperture adjustment
On my Epicure, you are supposed to press the bake selector pad then press the + button to set the temperature to 500 degrees or higher.  Then hold the bake button for 5 seconds.  The temp display is replaced by 00.  Release the bake pad and use the - or+ buttons to adjust the temperature in 5 degree increments.  When finished push cancel (or just do nothing).  Good luck.  I tried this and my oven kind of went haywire.  It decreased the temp by much more than the 10 degrees I had set it too.  May be something else wrong with my oven though?
Nov 18, 2007 | Dacor Epicure ERD36 Dual Fuel (Electric...
Viking VCSB423 Side by Side Refrigerator Logo
22 people viewed this question
Top Viking Refrigerators Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
Joseph Hoffmann
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
