Speedqueen awm593w2 my speed queen is leaking water towards the top
  • 177 Answers
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Posted on Jul 29, 2008
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
  • 5 Answers
SOURCE: speed queen
I'm sure you have already bought a new washer BUT......
The repair isn't as hard as you are lead to believe.
First I would check for leakage from the pump.
This is the Most common reason for water under the machine
The pump is a fairly straight forward repair that is a little different on each model of washer, but is usually easy to figure out.
If it is the seal/bearing then that is a more involved repair but not impossible for the average person who is mechanically inclined.
The front panel must come off, the the top panel, which is held by two screws in the corner. Lift the top back and disconnect the tub inlet hose. Push it out of the way. I wedge it into the top groove.
Pop off the water level switch hose on the back of the tub.
The tub module needs to come out. It is held upright by several springs. The number varies with the year.
A ready made spring hook can be found by removing and using one of the front springs. I use the one in the front to the left. It's the easiest. It's easier to catch the springs if you hold your hook facing up.
Disconnect the motor harness, leaving the capacitor attached to the harness. Pull it through the frame and out of the way.
Dis-connect the drain hose. there will be water in it so be prepared with towels. Place an old towel on the floor. Now lift the tub module up and out, setting it on the towel. This will keep grease. etc off the floor.
The tub top clips on. Gently pull the tabs out and lift two at a time, just until you break the seal, no more, till you have all of them loose.Remove and put aside. Take out the 4 tub bolts. Don't worry if you break them, the new kit comes with new bolts. The tub is usually stuck to the hub. Put a foot inside the tub and stomp down on one side. It will pop loose. Put tub aside after cleaning old gasket from bottom.
SPECIAL TOOL; you with need a 1 1/2" socket of shrt handled wrench to remove the large nut.
Once it is off there is a nylon lock unit in the grooves with the threads that looks like a crown, cut a slice in it and pull it off. There is a new one supplied.
Remove the hub. Sometimes a puller is needed, don't damage the shaft or threads.
Turn module over.
Remove the 6 bolts around the outside of the tub, the motor bolts on some models and the two holding the counter-balance to the tub.
Lift off the transmission assembly as a unit.
The seal kit has the instructions for your particular model.
If the bearing is a separate 3-bolt unit, replace it as well.
Never leave a bearing that has gotten wet from a leaking seal, or you WILL end up doing the job again in a few months because of a $15 bearing that should have been replaced the first time.
Re-assemble the washer in reverse order.
Spray WD-40, or other lube, on the cork gasket between the tub and hub before installing tub.
Don't forget the nylon lock unit.
If the pump looks like it has been leaking At All, Replace it Now.
When installing the springs, do the back ones first. Hold the hook facing down this time. Install the one you used for a tool last and in the front left side.
Let the washer set for an hour before use, or as directed in the seal instructions. The first cycle should be hot water, without a load .
Posted on Apr 27, 2009
  • 142 Answers
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
Posted on Sep 14, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
Is there a solenoid on the block of the 1.7d 2003
we have no idea what you have the question shows speed queen washer water valve
Oct 08, 2015 | Speed Queen Speedqueen Soleniod, water...
I NEED A MANUAL FOR SPEEDQUEEN TOPLOADER LWS21NW
You can get a manual online from Speed Queens Website( Alliance Laundry)
Feb 02, 2013 | Speed Queen Washing Machines
My speedqueen top loader starts to fill up with water and every once in a while it overfills completely and overflows. It does not happen every time. Where can I check the switch /mechanism to stop...
There is a reset water level function on the front panel. To alter the water level each time you need to reset your water level . Ours used to do the same thing before my wife realized she was over filling it.
Jul 26, 2011 | Speed Queen Washing Machines
I need the manual for speedqueen LES 17AWF
Try this website. It is a speed queen website. http://www.speedqueen.com/comm/support/downloads/manuals.asp
Apr 30, 2011 | Speed Queen AES17AWF Electric Dryer
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Feb 03, 2010 | Speed Queen ATS90AWN Front Load Washer
good luck
Mar 21, 2009 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
