Question about Motorsports
Light flashes on conrol panel when in 4 wheel drive
  • David Dec 12, 2014
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    1. what kind of vehicle
    2.which light is flashing?
    New Friend:
  • 36 Answers
This would be better answered if you gave the make & model of Vehicle. Contact one of their supply garages, it may well be that it is made to show that you are in 4 wheel drive, especially as this uses more fuel. crossf
Posted on Jan 28, 2015
4 wheel drive on 2001 chev blazer won't kick in..lights flash, hear sound under floor board as if something moved/slid but won't go into 4 wheel
It sounds like the motor for engaging the 4wd isn't completely engaging, you're going to have to crawl under the truck and watch it while someone engages it. I cannot express enough how dangerous this could be to the person who climbs under the vehicle, take every precaution necessary even as far as lifting the truck up on jack stands on all 4 corners with all wheels off the ground.
Oct 25, 2016 | Cars & Trucks
I have a 4 wheel drive 1993 ford f150 and i replaced the little motor that controlls it. but the 4 wheel drive doesnt want to work? what could ot be?
sounds like you getto chase wires but did you try the sillinoid befor u put it in. if not take it out and have some one try to push the button and see if it enguages
Jan 04, 2013 | 1993 Ford F150 SuperCab
Stuck in 4 wheel lo, how do i get it back to 2 wheel hi ?
On these issue, there are few solved help links for troubleshooting the issue easily.-------
Click the link below: ---
No 4x4 light on dash?
http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
4X4 Truck makes roaring noise in the front end?
http://schematicsdiagram.blogspot.com/2012/01/4x4-truck-makes-roaring-noise-in-front.html
Car will not go into 4WD high or 4WD low?
http://schematicsdiagram.blogspot.com/2011/12/car-will-not-go-into-4wd-high-or-4wd.html
4 wheel drive system will not disengage?
http://technoanswers.blogspot.com/2012/01/4-wheel-drive-system-will-not-disengage.html
4WD light is flashing and beeping? NO 4WD high?
http://schematicsdiagram.blogspot.in/2012/02/4wd-light-is-flashing-and-beeping-no.html
2002 Jeep Wrangler: 4WD Idiot Light is ON?
http://technoanswers.blogspot.in/2012/06/2002-jeep-wrangler-4wd-idiot-light-is.html
Traction control switch will not engage on 4WD High or Low
http://whoisbyme.blogspot.com/2012/10/traction-control-switch-will-not-engage.html
4WD light flashing and 4WD will engage after few minutes
http://repairhelpcenter.blogspot.com/2012/10/4wd-light-flashing-and-4wd-will-engage.html
2008 Toyota Tundra: 4x4 Wheel Drive Light is Flashing?
http://technoanswers.blogspot.in/2012/05/2008-toyota-tundra-4x4-wheel-drive.html
4x4 front differential will not engage the axle on ford?
http://technoanswers.blogspot.in/2012/02/4x4-front-differential-will-not-engage.html
4x4 will not engage on Ford F150?
http://technoanswers.blogspot.in/2012/02/4x4-will-not-engage-on-ford-f150.html
Dodge Ram 4x4 light keeps flashing
4X4 LOW LIGHT IS FLASHING ON DASH
http://technoanswers.blogspot.in/2012/09/dodge-ram-4x4-light-keeps-flashing.html
Ford 4x4 front wheels will not engage?
http://technoanswers.blogspot.in/2012/02/ford-4x4-front-wheels-will-not-engage.html
These details will help.
Thanks.
Dec 09, 2012 | 1999 Chevrolet Blazer
2002 chey trailblazer 4by4 light on the swich stay on 2 wheel drive if i put into 4 wheel drive or all wheel drive and one light flash on where ever i put the swich on. feels like is goes in 4 wheel high...
The Transfer Case Control Module (TCCM) in this model year have been known to hang up, try pulling fuse #48 (4WD) in the rear fuse panel located under the left rear seat. Reinstall fuse and see if everything works OK, if not, you probably need to replace the TCCM.
Dec 07, 2010 | 2003 Chevrolet TrailBlazer
I HAVE A 2002, 4-WHEEL DRIVE, TOYOTA TUNDRA PICK-UP TRUCK. IT HAS A 4-WHEEL DRIVE PROBLEM. RECENTLY I USED THE 4-WHEEL DRIVE, IN HI-GEAR. IT PERFORMED GREAT. WHEN I DEPRESSED TO BUTTON ON THE DASH TO...
I was researching the recalls for the 2002 tundra and havent found any recall pertaining to the 4whl drive. Sometimes when people have their 4wheel drive locked in and drive on pavement for any length of time, whether it be just a couple of feet or a couple of miles, over time it creates a binding of the gears in your transfer case. Once the bind is so great, the engaging and disengaging starts malfunctioning and leads to bigger problems overall. I could be wrong about this being the problem that you have but I think its something to look into. It wouldnt hurt to put your vehicle up off all fours and release the bind if any by running through the gears while in 2 and rour wheel drive while all four tires can move freely and release. See if that works for you. Check your gear oil front , center and rear and use much caution when attempting this suggestion. Also refer to your owners manual troubleshooting section for other possibilities. Merry Christmas. By the way, the electrical switch should be covered in the troubleshooting section also.
Dec 04, 2010 | 2002 Toyota Tundra
4 wheel drive and 4 wheel low lights started to
Have vehicle's TCU/TCM scanned for codes and do the repairs the codes address.
Currently 4wd, 4wd low and overdrive do not work.
Jun 21, 2010 | Ford F-250 Cars & Trucks
While driving my 1998 ford explorer the 4 wheel drive lights on the panel flash on and off both of them hi and low together
I seen this once before owner had 2 different size tires so the 4 wheel drive was reading a slip in one of the wheels. And the 4 wheel drive was going on and off.
They replaced the tires with all 1 size and it went a way.
Jun 04, 2010 | 1998 Ford Explorer
My transfer case is permanently engaged but no 4 wheel drive...
2 common problems that cause this are the vacuum switch on the transfer case and the vacuum actuator mounted under the battery tray. When the switch on the transfer case goes bad it pulls fluid out of the transfer case and pumps it into the actuator and destroys it. The switch only costs about $15 and are usually stocked at major auto parts stores. The actuator ranges from about $50 to $120 and most of the time need to be ordered. If you reach under the battery tray with the 4wd engaged and follow the cable you will feel the end of the actuator, make sure that it is pulling back. If not either the switch or actuator or both are bad. Hope this helps.
Jan 08, 2009 | 1999 Chevrolet Blazer
Motorsports Logo
362 people viewed this question
Top Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
Trp Nap
Trp Nap
Level 1 Expert
Are you a Motorsport Expert? Answer questions, earn points and help others
