Question about GE Profile JGP636 Gas Cooktop
Flame looks like wind is blowing the burner
Flame blows like its in the wind
GE Profile Gas cooktop burners blow out
This sounds as though the pressure is too high.
Feb 11, 2015 | General Electric PGP953DETBB GE Profile...
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
Viking stove burners blow out and relight if you tap gas valve. Hot surface igniters glowing but burner still loses flame and then make gushing noise. Is it the valve or the worn igniters?
Which model do you have? Sound s light your unit re-ignites if flame goes out, if so, I would clean the burner. This means with a old toothbrush remove everything baked or burnt on. Assure your small orifice with in the burner is clean and you can see the port (hole in the center). Most of the time I have found clogged burners, or the burner cap (selected models) were installed incorrectly to cause this issue. Give that a shot and get back to me if you have more to add or just more questions.
Thanks
Oct 17, 2013 | Cooktops
No flame touching thermocouple
There must be a blockage on the inner flame ring as the gas is not getting to the thermocouple .
Apr 21, 2017 | Gaggenau 11 in. VG 232 Gas Cooktop
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
One of the igniters does not click. they were wet and popped the breaker over a week ago . all but one now clicks and lites burners. it was sparking a weekago and blowing the breaker.
Make sure the area of the burner base around the spark electrode is clean (use a fine sand paper). The little hole for the gas is open (use a paper clip). You won’t see a flame unless the burner head is on. If this doesn’t help, check the bottom of the spark electrode visually. Make sure the wire is attached to the electrode and is not loose (pull it a little bit.) If the wire or the electrode is damaged, replace it ($25). If not, locate the spark module and switch the connection with another one (they are different colors). If you get flame on the same burner, but not on the other one, replace the spark module ($60). When you work with electrical components, turn the breaker off. When you test, turn it on. Good luck.
Sep 14, 2009 | GE 36 in. Profile JGP962SECSS Gas Cooktop
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Burner goes out when cabinet door is opened!
i haven't worked on one of these models hands on but on most you can pull the burner **** and look inside you should see a tiny ***** in there hold the outer piece with a pair of pliers and take a tiny screwdriver and after turning the burner on turn the ***** to adjust the flame just enough so the suction doesn't blow the flame out on the lowest setting
Mar 08, 2008 | Cooktops
Burners will not light or stay lit
lhs burner - problem is probably thermo-couple. this is a safety device which prevents gas escape if flame blows out. rhs burner - you do not say if it can be lit by a match. if so then it is a problem with the electrode or the wire to it chaffed thro. if can't be lit by a match, then a problem with the gas valve which is unusual not a diy fix unless you are experienced
Apr 11, 2007 | Miele 30 in. KM320G Gas Cooktop
GE Profile JGP636 Gas Cooktop Logo
74 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
