Question about Magimix Food Processors
Magimix 4200 The egg whisk works for about first few minutes, then starts banging loudly and seems to come out of position? Its a new 4200XL bought last December. Everything else OK but only tried egg whisk Twice, parent use it again!!
2 Suggested Answers
  • 248 Answers
SOURCE: When I use the egg whisk attachment on my 'Le Mini
the attachment is likely bent out of shape making it off balance.I would suggest a new one ,if you dont know were to get one already try-searspartsdirect.com
Posted on Oct 12, 2010
How to remove a stuck blade from a magimix
Correct repair is to replace both the blade and the motor shaft so drilling a hole sideways thru top of the blade to give you something to grip against is easiest. You need to protect the bowl because it's not necessary to replace that part. A couple of bits of wood across the top either side and then a screwdriver into each side of the hole you have drilled should give you enough grip to lever the blade off.
Sep 06, 2014 | Magimix 4200XL Chrome Food Processor...
Magimix 4200 xl won't turn on
Check that the bit on the lid that activates the switch pushing mechanism in the bowl is working properly.
Aug 27, 2014 | Magimix Food Processors
How do I change the Nylon Driveshaft on my Magimix 4200?
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and support the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Aug 26, 2014 | Magimix C.s.4200 xl chrome mat - Mixeur...
The extension post in my magimix 4200 is stuck on the motor shaft seems like It's welded on can anyone help
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix Spares Parts from BBS Ltd
Apr 03, 2014 | Food Processors
New magimix won't start
It is most likely the way the bowl and lid are set.
Facing the machine:
the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Feb 01, 2013 | Magimix 4100 Cuisine Systeme 1268 Cups...
Need a manual for cuisine 4200
Magimix makes the Instructions for Use for the Cuisine 5200 available on their website:
http://www.magimix.com/upload/notice_d_utilisation/ma_cuisine/download_usa.pdf
If you don't mind paying a small fee there is also an Instruction Book available here that may also be applicable to the 4200:
http://www.magimix-spares.co.uk/Magimix-le-micro-instruction-book-and-le-micro-recipe-book/product/54138/54138/
Nov 01, 2011 | Magimix 5100 Cuisine Systeme Food...
When I use the egg whisk attachment on my 'Le Mini Plus' model Magimix it vibrates and makes an awful lot of noise and it takes much longer than it used to whisk the eggs sufficiently. Any suggestions...
Oct 11, 2010 | Magimix Le Mini Plus 719 Cups Food...
I've just purchased a Magimix 4200XL and only have one large blade, this does not fit into the small bowl?? None of the included parts fit this bowl, is something missing? Julie
I solved the problem by contacting the retailer i bought it from who promptly gave me the 'missing' blade from one of his other 4200XL units. He said it must have been accidentally packed at the manufacturers without it.
Happy Customer now :)
Jul 30, 2009 | Magimix Food Processors
Food Processors Logo
Top Magimix Food Processors Experts
Oloyede Monsuru
ray gallant
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
