Question about Frigidaire Refrigerators
No display, not running, beeping from Controll
Model# glhs37ehsb6
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: frideidare model glhs37ehsb6 not cooling
Hi bluesummerpe,
If your machine is not cooling and making a constant beeping noise, it might caused by connection with the door. There are several ways on how to correct this problem, either you add something to the door that will increase the connection or check if the compressor is running. Here are additional steps that you may apply on this issue.
1. Check the connection with the door. If it's a connection problem, try to add something to the door that will increase the connection. You can use a foam tab with a self stick side. Place it on the part of the door where the contact with the switch.
2. Check the compressor. If the compressor is running and you noticed that the machine is not blowing cold air inside the freezer. You may have either a restriction inside the sealed system or have a leak in the sealed system and all the Freon has escaped. It is like no Freon, No Cool.
3. If the compressor is not running, you need to check the motor. Either the motor is not getting power and that's why its not running, or its getting power and the windings inside are shot and that's why it's not coming on.
Hope it helps.
Thank you for using FixYa.
Posted on Mar 28, 2011
Frigidaire GLHS37EHSB6 beeping
The connection with the door and switch on some refrigerators is not good, you need to add something to the door that will increase the connection. A foam tab with a self stick side placed on the part of the door where contact with the switch is made works just fine.
Oct 16, 2012 | Frigidaire FRS3R5EMB Side by Side...
My Whirlpool doudle oven #RBD305PDB14 was working fine and now the display is blank and it only would beep at you. the interior lights would come on but no use of controlls. It has been powered off at...
There is a thermal fuse at the connection for the control board.
Had the same problem. I repaired the board myself and ordered a replacement from sears parts direct. It is a repaired board not a new one but has the same warranty. You can get this board a lot faster. Here is the link. http://www.searspartsdirect.com/partsdirect/part-number/8302319R/0022/664. If you would like to repair your own board leave a post and I will help you.
Nov 20, 2011 | Whirlpool RBD305PD Electric Double Oven
The Frigidaire Galaxy Series Model GLHS37EHSB6 is not cold. The temperature shows freezer at a temperature of 65 degrees and refrigerator at 77 degrees. I have lowered the temperature and it would beep and...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Frigidaire Refrigerators
Frideidare model glhs37ehsb6 not cooling and making a constant beeping noise....what can i do???
Hi bluesummerpe,
Hope it helps.
Mar 28, 2011 | Refrigerators
UNIT NUMBER GLHS37EHSB6 WON'T STOP BEEPING WHAT SHOULD I DO (REFRIGERATOR)
Hi!!The connection with the door and switch on some refrigerators is not good, you need to add something to the door that will increase the connection. A foam tab with a self stick side placed on the part of the door where contact with the switch is made works just fine.
Don't forget to rate this post!!
Sep 14, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
No picture and beeping sound emitting from unit.
We have had ALOT of samsungs in the shop lately and the most resonable solution for these units is just to replace the controll box as a whole. goto www.vancebaldwin.com and login as guest and search for it by model #.
Sep 15, 2007 | Samsung SlimFit TX-S2783 TV
Refrigerators Logo
27 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
