Lg wm12336fd Clothes smell when clothes washed
SOURCE: Clothes Smell Musty and Damp
It sounds like a build up of washing residue. Clean inside the door seal and do a very hot wash with a bit of washing powder and no clothes. Repeat this once a week until smell has gone.
Posted on Jan 06, 2009
SOURCE: clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Posted on Jan 10, 2009
  • 298 Answers
SOURCE: have a philco ecotronic washing machine and the
The problem is design. Not all of the water is getting out after each cycle and not all of the soap gets fully dissolved. After awhile, this mucky slime gets 1n the drain hoses, pump and filter - and they all smell musty - especially when the machine sits empty with the door closed between loads.
You need to clean the innards of the machine by doing a load without clothes on hottest setting (Whites) and depending whether the smell is bacterial (add 1 cup White Vinegar), fungal (add 1 Cup Bleach) or clogged filter (add 1cup Arm and Hammer with 1/4 cup SALT), this should do it
(Vinegar for Bacteria, Bleach for Fungus and Arm and Hammer with SALT to soften and loosen the slime)
Choose from above (not all 3 at once tho) and fill the machine with water and let run without clothes.
I would do the A&H with salt first, let cycle complete, then restart and add a cup of Vinegar, tel cycle finish then redo with 1 cup bleach
After treatment, leave the front door open after doing laundry from now on so it can thoroughly dry out and get air circulation. - Just open, not WIDE open ;-)
Posted on Mar 26, 2009
SOURCE: My washer a Tromm LG
Sears has tablets for front load washers that work great. I use one every month and it has helped the stinky washer smell and the bad smell in the clean clothes. It is called Affresh and it works better than any of the cleaners you can buy in the grocery stores.
Posted on Apr 20, 2009
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
LG WM2050C* MILDEW & MUST SMELL
Did you check to see if it has a filter to it, If there is one that would most likely be the problem
Dec 18, 2015 | LG Washing Machines
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bad smell in washing machine...clothes smell bad after wash
hi there is a build up of lime and old dirt in the inside of your drum the best thing to get rid of the smell is put a very small amount of bleach in the drum and put your machine on a very hot wash it will help in your hand book it will tell you to use your hot wash with a bit of powder and no cloths at leased once a month i dont know if you use your hottest wash most people dont these days because of the low temp powders, also the best product to use is lim away but you can only get it on usa bases or from the usa you might find someone on line that sells it that will get rid of all the lime thats been built up in your machine if you cant just use a bit of thick bleach hope this was helpful
Nov 18, 2011 | LG WM-2277HW Front Load Washer
Clothes stink after washed in lg front loading machine
You may have already found a solution, but I had this exact same problem. I ran the tub clean cycle with bleach and then switched to a powder HE detergent. I found some other posts that said that liquid HE detergent has some thing in it that causes that smell and the tub build up (not sure what?). I was hesitant that that could really make a difference but it has. It has only been a week, but so far everything smells great. Definitely worth a try.
Jul 20, 2009 | LG WM-2277HW Front Load Washer
Clothes not fresh as with a topload washer
Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
Jul 04, 2009 | LG WM-2277HW Front Load Washer
Jun 12, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Clothes smell......
The following are the methods you can avoid odor in clothes after washing.
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
Good luck.Please do post comments if the problem is still not solved or if there are any doubts in this post.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer a Tromm LG DLE377W leaves a bad smell in clothes after washed the smell is in the washer also smells sour
Aug 07, 2008 | LG Washing Machines
Clothes smell musty
Clean th filter in the front of tha machine. Than take an OLD towel and run a hot wash with chlorox.
After that you run it again with vinegar and that should relief your problem.
i have an LG too.
Jun 21, 2008 | LG WM-2077C Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
