Question about GE Washing Machines
Ge profile wpdh8800joww
Stops during mid cycle.
JULIANFIX
  • 975 Answers
SOURCE: GE Washer stops during cycle
CHECK THE SENSOR SWITCH underneath the washer where the door closes , it could be loose or damaged, hope this helps AJ
Posted on May 09, 2008
jumptrout51
  • 3361 Answers
SOURCE: washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Posted on Apr 06, 2009
  • 130 Answers
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on May 07, 2009
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
Posted on May 13, 2009
  • 3 Answers
SOURCE: GE washing macine stops during the wash cycle
This is exactly what my machine was doing, as well. I fixed it by cleaning out the filter in front of the water pump.
Searching here, I found that you can remove the lower front panel (three screws along the bottom edge is all it takes) to get to the filter. With the panel removed, you'll see a round white plastic cover (about 3-4 inches diameter) that screws out. Get a bucket under the cover to catch the water that's in it (could be 2 quarts or more) and unscrew the cover.
The cover pulls out, revealing that is actually a screw-in plastic strainer. I found tons of coins, broken pens, paper clips, etc. in mine when I did this. A lot will be deep inside the black rubber hose that connects this filter housing to the washer drum. You can rake the stuff out with a bent wire clothes hanger. Shaking the black hose will help hurry the junk along and out of your machine. Screw the cover back on after the clean out and your machine should go back to normal.
Thinking about it, front loaders will have lots of small items flushed into the pump compared to top loaders. Coins you alway found in the bottom of the drum in a top loader, they all wind up in the filter of a front loader. And once it slow the drainage to a crawl the machine will shut down multiple times when it can't drain the water out completely, and it will never step up to it's max spin speed with all that water still in the drum.
Posted on Nov 30, 2009
Spin cycle stops and moter humms
clean the filter out may be clogged
Jun 16, 2012 | GE Profile Prodigy WPSE4200A
Stops in mid cycle can advance timer and will start running again
unplug the machine over night and try again. check to make sure there are no wires lying on top of the IC's on the control boardl. could also be a bad control board (timer)
May 25, 2010 | GE Profile Prodigy WPSE4200A
Washer stops several times in the middle of cycle
possibly it could be your un-balance switch getting very sensitive to any type of movement of the machine, normally they only actuate during the spin cycle when you have a very off balanced load of clothes
Oct 03, 2009 | GE Profile Prodigy WPSE4200A
Selector switch
Clutch assembly
Drive motor
May 07, 2009 | GE Profile WPRE6100G Top Load Washer
Stops during cycle
you must reduce water on faucet
Feb 16, 2009 | Kenmore Elite 45986 Front Load Washer
Ge profile whsb8000bocc
Washer is most likely trying to fill with cold rinse water and the inlet screen is blocked or the cold water solenoid is bad. If you set washer to wash cold only it will not fill or fill very slowly. When you set it to warm or hot you are getting almost all hot. Clean inlet screen or replace inlet water valve.
May 12, 2008 | GE Profile WPSR3120WWW
Nov 17, 2007 | GE WHRE5260E Top Load Washer
Washing Machines Logo
19 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
