Reset transfer belt on oki c3450 - Office Equipment & Supplies
Soulvisitor
  • 1113 Answers
SOURCE: oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Posted on Dec 21, 2007
  • 59 Answers
SOURCE: LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Posted on Mar 23, 2009
  • 24 Answers
SOURCE: Oki C5500 printer keeps jamming
Open the tray and find yout imput roller. You can remove this roller and put it back on the other side. Normally this is caused because it is worn. The inside of the roller is like a new one.
Posted on Jan 24, 2010
alpug
  • 1961 Answers
SOURCE: I have an Oki c9650
not 8 0\'s...... use only 6
password is 000000
Posted on Oct 18, 2010
evan89
  • 356 Answers
SOURCE: transfer belt warning on oki c3200. How do I reset
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Posted on Mar 06, 2011
Where does oki c9500 waste toner box located
Your printer does not have a waste toner bottle. Waste toner is stored within the transfer belt. When full it will give you an error indicating its time for a new transfer belt.
Jul 08, 2017 | OKI Office Equipment & Supplies
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
What might be wrong with my OKI C3450 printer? it keeps flashing and it doesn't print.please help me
try uploading the original software and reboot it then it's a new baby...don't have original software...just google free software for...(your model)...join any site that askes for you to join for free and your set...also, make sure you cartridges are in their correct position...try removing and replacing a few times for better connection
Dec 09, 2011 | Office Equipment & Supplies
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
Jan 11, 2010 | OKI C5500n Printer
Mar 23, 2009 | Office Equipment & Supplies
Fatal error 917 on an Oki C9600 printer. What does this mean and how can I resolve the problem. Many thanks James
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Jan 07, 2009 | OKI C9600hdn Laser Printer
Fuser reset / transfer reset
RESET OKIDATA TONER DRUM by RTINSC (11/17/05 10:34 AM) reply + / -
8. Restart printer.
Aug 11, 2008 | OKI C5510 MFP All-In-One Led Printer
Oki 9800 230 fatal error
Dec 07, 2007 | OKI 9800hdn Laser Printer
jasbo
jasbo
