Question about Kodak ESP C310 AllInOne InkJet Printer
Printer says out of paper, but paper is in the tray, it will pull a sheet of paper down halfway then stops and says to add paper.
4 Suggested Answers
  • 45 Answers
SOURCE: KODAK ALL IN ONE 5500 PRINTER KEEPS SAYING PAPER TRAY IS EMPTY
Shut down everything, printer and computer and try again.
Posted on Dec 22, 2008
  • 285 Answers
SOURCE: I have a Kodak easyshare
try pushing the copy and cancel buttons simultaneously if it doesn't work call 1.800.421.6699
Posted on Jan 28, 2009
gunzzzz
  • 391 Answers
SOURCE: My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Posted on Nov 23, 2012
Bl;ack streaks on paper
Pull down the manual feed tray door.
Load a few sheets of paper in tray 1.
Print something.
As the paper feeds into the printer observe it.
When the paper gets halfway in, open the top cover.
Lift out the toner and look down at the paper.
Does it have a black streak? If yes...change the toner.
If no...change the fuser.
Feb 22, 2011 | HP LaserJet 4 plus Printer
SCX-4216 "No Paper" message
Check this link it has a step by step solution that you can try http://www.fixya.com/support/t216317-no_paper_error
Hope that helps..........
Aug 07, 2008 | Samsung SCX-4100 All-In-One Laser Printer
I have a HP Laserjet 4250 that is printing dirty prints. I have replaced the toner and the fuser unit and cannot correct the problem. I have 2 of these printers and the toner and fuser unit works no...
Try printing from the manual feed tray(tray 1). Put a few sheets of paper in the tray. Print anything that is more than two or three sheets of paper. The paper path test is good, 10 sheets. As the paper gets about halfway into the printer, open the top door. Pull out the toner cartridge. Look down at the paper. If it's dirty it has to be the toner or the transfer roller. If it's clean it could be a dirty paper path or fuser.
Vacuum out the printer, if you have mounds of toner laying in the paper path, everything that comes out of the printer will be dirty.
Aug 02, 2010 | HP LaserJet 4250n Printer
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
4. Close the front cover.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
E240 LEXMARK WON'T PULL PAPER FROM TRAY 2
Try pulling out the tray and looking for the feed rollers that pull the paper up into the printer. The 2 rollers should have rubber "shoes" on them (they look like thick black rubber bands). Remove these roller "shoes", turn them inside-out, and put them back on the rollers. This worked for me, maybe it will work for you too.
Mar 31, 2009 | Lexmark E240n Laser Printer
Printer does not fully pull paper...
You probably need to clean the rollers that feed the paper. Check your manual or go to Cannon web site.
Jan 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Won't print from tray 1...
Hi banelson: Tray #1 pickup problems
Possible Solutions:
1. Dirty,worn,or deformed multi-purpose tray pickup roller.
A. if dirty, clean the roller.
B. if worn or deformed,replace the roller
2. Defective separation pad.
A. if dirty,clean pad. if worn or deformed,replace pad
3. Damaged drive gears.
A. Check the drive gears in the pickup/feed area. if damaged,replace the gear.
4. Defective multi-purpose tray pickup solenoid.
Dec 19, 2008 | HP LaserJet 3600n Printer
Hp all-in-one ->Paper Jam: Clear jam, and then press OK error message
it may have more to do with the type of paper and your canon printer. did you check to see that the paper is compatible with the printer specifications?
Apr 22, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper Loading Problem
rollers can use a little cleaning sounds like..
Mar 23, 2008 | Lexmark X3350 All-In-One InkJet Printer
Kodak ESP C310 AllInOne InkJet Printer Logo
20 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
