Question about Refrigerators
Amana 36768 MK Frame
Meat keeper frame replacement
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Posted on Feb 27, 2008
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
Gatehouse door lock 482784. Bought at Loews Newmarket. Everything seems ok but the strike plate does not fit to a steel frame door. Is there a different strike plate for steel doors?
You will need to contact the manufacturer, an agent or study the complete catalogue but I think it is unlikely a keeper or striker will be available for a steel door frame.
Most likely the steel frame will need to be modified to accept the bolt and provide a suitable ramp surface for door closing.
Feb 24, 2018 | Locks & Locksmithing
Amana fridge model number Arb1914cw is not cooling. Freezer is working fine
Bottom freezer fridges are especially susceptible to
  1. Dust build up on the condenser coil that impedes heat transfer to the outside from inside the box
    • Remove the (bottom) footplate by grasping outside edges and pulling/levering out and popping it free.
    • Use vac crevice attachment and coil brush to clean away all dust from the coil and foot plate.
    • Replace plate and allow 24 hours for inside temp to stabilize.
    • Adjust top temp setting if needed to maintain safe temp level.
    • Repeat semianually or annually as scheduled maintenance--depending on the dustiness is fridge's location.
  2. Airflow blockage through the crispers and meat keepers.
    • Remove crispers and meat keeper as well as glass cover shelf.
    • Find cooling passages between crispers and at midline of meat keeper.
    • Remove any buildup of air blocking debris.
    • Wipe up fridge box floor beneath meat keeper.
    • Reinstall glass shelf, meat keeper, and crispers.
    • Check perodically for poor temperature/moisture keeping in crispers and for water pooling on fridge box floor as signs of blocked air flow through criispers and meat keepers.
Mar 16, 2015 | Amana Refrigerators
1996 mercury mystique a green light comes on and it say o/d off what does this mean
It's a transmission problem. Probably a bad TCC solenoid. Worst case is the valve body.
Feb 13, 2015 | 1996 Mercury Mystique
I am not sure I can be any clearer than to say the saw dooes not cut the tile square.
the problem is probably the slide cart you set tile on to push it into the blade,on the right side theres a roller you can adjust the the height of the tray,or look at the very bottom of the cutting arm,left hand side,on the outside,where its painted red, theres 2 bolts that hold the cutting arm to the frame of the saw body,try this first, i bet nuts got loose and the cutting arm dropped a tiny bit screwing everything up
Dec 28, 2010 | Mk Diamond Mk Tile Saw Mk-101 Pro24 10in
Cant find the fuel filter
Should be on inside of the frame, drivers side, between fuel door and door. Its held to the frame with round plastic keepers..
Dec 20, 2010 | 1993 GMC Sierra
Water is not cooling
Hi: This Wide by side is like all other side by sides as to how it stores the water. Storage will be behind the crisper or meat keeper in the form of a coil of tubing or a bladder to store the water. Pretty simple. The length of tubing running from the storage to the dispenser will not be chilled. Some refrigerators do this better than others. Try setting the ref. or meat keeper a little colder. Watch your vegetables so they don't freeze. Rare, but it's possible... Older homes (before dispensers,) when fridges just had ice makers, would tap into the hot water line for ice to freeze faster and be clearer. I know this sounds crazy but it's true. I lived in an older home and in the winter the hot water would always freeze first. I know this solution sounds lame but there really is nothing much to go wrong with the water chilling. Pull your meat keeper out and look at the reservoir and see how cold it is. Good luck, Jeff
Jun 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Front driver door rattles and the door open light comes on
You will have to adjust the door lock catch which is fitted on the body , loosen the two screws and push it a little inwards , close the door after adjsuting and see if it rattles , if so repeat the adjustment.
Please also check the door hinghes of they are ok! Probabely it may have some play if so thn you will have to replace them.
Hope this helps!
May 12, 2009 | 2000 Nissan Xterra
Please help -
I don't have it fixed yet but think I am in the process. When I installed the firmware, it didn't install properly which I didn't realize. I have now uninstalled it and reinstalled. It should work now - fingers crossed. Thank you for taking the time to look into this for me. M.K.
Jan 29, 2009 | Kodak EasyShare SV811 (8858946) Digital...
Fridge parts broken
Try checking HERE.
Geno
Mar 24, 2008 | Refrigerators
Feb 27, 2008 | Refrigerators
Open Questions:
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
