Question about LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator
LG LFC20760 thermostat froze both sides, freezer working but fridge not.
  • 489 Answers
SOURCE: LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Posted on Apr 29, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Posted on Jul 13, 2009
SOURCE: LG LDC22720SW ECU reads 5-6-7 on freezer side
I have a similiar problem with my LG refrigerator. The freezer settings get stuck on 6 and 7, while the refrigerator side is showing nothing. Pushing the buttons to adjust the temperature does nothing. The whole time, my food is getting spoiled.
Posted on Oct 18, 2009
  • 118 Answers
SOURCE: LG FRIDGE,, fan not working or is thermostat faulty?
fan bad or not defrosting look for ice build up behind panel by fan
Posted on Oct 26, 2009
woodchuck789
  • 4070 Answers
SOURCE: refrigerator cooling issue
If it's not a defrost problem then it will be a freon/compressor problem which has a 5 year warranty.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Posted on Jan 01, 2010
The fan inside the freezer won't run,freezer freezing up,no air going into fridge model ed22cq
OK, if the fan is not working and you have ice buildup on the coils, you will need to replace the defrost thermostat and the fan.
Here is the thermostat to order.
Here is the fan to order.
Nov 28, 2012 | Refrigerators
My lg fridge lrbn20514bk the thermastat is not working on the top control but for freezer is reading 567
This fridge LRBN20514BK with bottom freezer is a piece of junk. Just had the relay on compressor replaced and now the thermostat isn\'t working. Temperature on fridge reads nothing and freezer temperature reading 5,6,7. Then the freezer coils freeze up and no air blowing to the fridge. Ready to take this POS outside and blow it up. Only 7 years old and never ending issues. I will never buy LG again. EVER! LNG - Life is not good! HELP.....so what needs replacing? Thermostat? And of course I have to have repair man come in due to LG not selling parts to customers. Again I call BS
Feb 03, 2012 | LG LRFD25850 French Door Refrigerator
The freezer coil is froze up and the fridge part is not staying cold. Could it be because the coil is froze up or could it be a bad thermostat?
I had similar and was told to ( difficult I know) switch off and up-end the whole unit, which in my case was sucessful. Fridge now been working for over 2 years without any further problems.Worth a try !
Feb 02, 2012 | Kenmore Side by Side Refrigerator
Maytag side by side. Coils froze solid, no cooling in fridge or freezer. Replaced heat coil and thermostat assly., as well as adaptive defrost control (circuit brd.). Still don't seem to be able to...
Hi Rob,
The problem in your case is most probably with the defrost thermostat.
It can be found on the evaporator i.e. freezing coils , it's round disc like with two wires.
If you get this replaced with a new proper working unit ,
Also make sure you replace the defrost timer as well if the problem persists.
Hope this helps ..:)
Jun 24, 2011 | Refrigerators
Freezer froze,ice and frost,freezer door froze, warm in fridge
change thermostat sensors in fridge and freezer easy
Feb 04, 2010 | Refrigerators
Error code er ff.how do i fix this? freezer is still freezing but fridge is warm.
The error code appears when there is an abnormality of BLDC FAN Motor for Freezer. It circulates cold air from the freezer to the fridge to allow cooling. Check the motor wiring harness for poor connections. If the motor is not working at all, you need to replace it.
To remove the fan and motor assembly:
  1. Remove the freezer shelf. (If your refrigerator has an
    icemaker, remove the icemaker first).
  2. Remove the plastic guide for slides on left side by
    unscrewing phillips head screws.
  3. Remove the grille by removing one screw and pulling the
    grille forward.
  4. Remove the Fan Motor assembly by loosening 2 screws
    and disassembling the shroud.
  5. Pull out the fan and separate the Fan Motor and Bracket.
  6. Replace fan motor assembly in reverse order.
Oct 27, 2009 | LG LFX25960ST Stainless Steel French Door...
Whirlpool gold side by side refrigerator is not cooling correctly. Inside temperature on setting of "6" was 41 degrees. On "5" it read 39 degrees. Noticed that it seemed warmer than usual yesterday and...
Greetings,
I'd be looking at a froze over evaporator.. The freezer usually will seem okay, and the refrigerator will be getting warmer. however, after awhile even the freezer will go out if its froze up.
The thing you need to do is determine if your freezer evaporator is frosted. If so, the air will not be able to draw thru the evaporator and get over to the fresh food section. So, defrost the coil if it is froze up and this will give you temp service.
Its difficult to troubleshoot this,but if you have a ohm meter, you need to check the resistence of your heater and defrost thermostat. if these are good..Its possible your adc is defective..9The timer)
Sep 25, 2009 | Whirlpool Refrigerators
LG ICEBEAM GRS512GC. Freezer cooling but fridge not cooling. Just had tech replacee fridge pcb with no sucess... any suggestions? thanks in advance :)
check to see if fan inside freezer is running.
is the evap coil in freezer froze up ?
if fan is running and coil is froze up u need a defrost timer.
Sep 23, 2009 | Refrigerators
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Fridge not staying cool, freezer still freezing
Try defrosting freezer, sometimes when the defrost thermostat fails it causes ice too build up behind the walls of the freezer then it restricts the air flow to the refer side. If it works after defrosting then you probably need to get a new defrost thermostat.
Mar 14, 2009 | Maytag MBB1956GES Bottom Freezer...
LG LFC23760ST Side by Side Bottom Freezer French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
