Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna 61 rebuild cylinder and piston - Husqvarna "Chain Saw - 16" Bar, 3 Hp
  • 3 Answers
SOURCE: Piston ring compressing
Don't use a rubber mallet! It shouldn't take that much force! Make sure the piston ring is compressed enough so it will fit inside the cylinder as you slide it down over the piston. Be very delicate! It doesn't take much effort to break a piston ring or screw up the crank bearings. Just take your time and make sure everything is lined up and extremely clean.a thin coat of 2-stroke oil on the piston, rings, and inseide the cylinder will help protect everything - just make sure you're working in a clean environment where there's no dirt and grime for the thin coat of oil to attract.
Posted on Apr 20, 2009
  • 7 Answers
SOURCE: need diagram of husqvarna 141
Not sure why you would need these! This is a really simple process. Remove bar and chain brake cover. Disconnect choke and throttle lever, muffler, and 4 screws with your allen wrench, i've never even attempted it before and just took my about an hour to complete the entire process. Just make sure to note how carb goes together, you can mix a few parts up if your not careful.
You can find aftermarket kits to with cylinder, pistion, rings and all for around $60-100.
Posted on May 07, 2009
dontbother10
  • 2220 Answers
SOURCE: HUSQVARNA CYLINDER & PISTONS 575XP
IPL for a 2009-04 pn 537 25 41-02 575XP (complete) here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Bailey's P&C only $351.28 + shipping
http://www.baileysonline.com/itemdetail.asp?item=537+25+41+02&catID=383
HTH
Lou
Posted on Oct 01, 2009
nova2nv
  • 197 Answers
SOURCE: I am rebuilding a 261 Husqvarna chainsaw.
Arrow towards muffler.Torque is no more than 60 INCH pounds
Posted on Jan 09, 2010
Testimonial: "This answer was exactly what I needed to know. Thank you."
dontbother10
  • 2220 Answers
SOURCE: what year was my Husqvarna 61 #5450433 made?
I got this directly from Husky
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
With your serial
It was the 433 Husky product produced;
The 45th week of;
19- 75, 85, or 95. Contact them. Black on silver or silver on black on the serial tag is one way to verify age but it is my ability to provide an informed answer.
HusqvarnaUSA.com Contact Us
http://www.husqvarna.com/us/homeowner/support/customer-support/
HTH
Lou
Posted on Feb 07, 2010
Saw starts, but why does it run few seconds then quit?
Has it enough compression ? because i have the experience it have a questionable closing system for carburetor air filter it is not always fully locked take care to close it replace parts if its not as soon as this problem is there or its to late , on the way it should but when it is not good closed it leaks in much cases and the piston had often grooves by polution from graveldust it can have lost compression by it first to do is control the piston.
In the event that all of this is not the subject the tank airiation and fuelhoses to control.
51MM Cylinder Piston Kit For HUSQVARNA PARTNER K750 K760 REP 506 38 61 71
Feb 11, 2016 | Husqvarna K760 Cut-off Saw,2-cycle...
Hello, i have an old L65 Husqvarna chain saw, i have been lookin for a piston kit, but with no luck, i was told that old style 48mm piston out of Husqvarna model 61 will work in a l65 . Can any one co
I have a homelite piston running in my Husqvarna edger . Most pistons for engines are all the same if the cc's are the same . they only vary in the gudgeon pin size and the location of the pin in the piston. So take your piston to a small engine wreckers and any piston that measurers the same ,looks the same will do the job. then get a new piston for the make that it came out off and it will fit.
Mar 28, 2014 | 1993 Nissan Pathfinder
Husqvarna 250 Brush Cutter Piston and Head Scratched
the cylinder if it has small scuff marks can be honed out using a large brake cylinder honer in an electric drill
scratches on the piston can be removed using emery paper
the ring/ s need to be replaced
remember that the rings are pinned in position when being assembled to keep the eng gap away from the port holes
your statement indicates that it was run with out the correct oil ratio so check for big end and little end bearing coloring ( blue or tan color) before assembly
May 04, 2017 | Garden
Do you hawe parts for a husqvarna 254 piston end rings my mob number is 00353 85 730 98 28
The pisto is readily available from any Husqvarna dealer, the part no. is 503503701, there are also plenty of pirate parts available on the web
Apr 04, 2011 | Husqvarna Chainsaw Piston Kit for 61...
On top of the piston there is an arrow with the letters AB what does this keen?
just looked at a couple of pistons not sure what the letters mean ,,,but when installing the piston make sure the arrow always points to the exhaust port of the cylinder
Mar 29, 2011 | Husqvarna Chainsaw Piston Kit for 61...
I have a husqvarna 61 it wound pull over with the plug in but with it out it pulls over just fine
Assuming you have fitted the correct spark plug ( BPMR6A ) then it has to be an issue with the piston, if this is a after market piston it could have poor tolerences, the piston crown should be completly flat, not domed, if the piston is slightly too tall it will increse the compression to the point where you can not crank the engine, take the piston out and carfully compare it with the old piston.
Jan 21, 2011 | Husqvarna Chainsaw Piston Kit for 61...
My husqvarna 61 starts fine and runs great for about 15 seconds and the it flat out stalls. Over and over this happens. what can i do?
Make sure the chain can be turned by hand and is well oiled. Check the muffler, fuel filter, and air cleaner for plugging. Check the condition of the fuel lines and primer button--does the primer pull fresh fuel into it when pumped? Check the carburetor fasteners for tightness including the mounting to the cylinder. If there is a rubber isolator between the carburetor and cylinder, check it for cracking or any holes. Make sure you are using modern synthetic saw oil in the fuel, not boat motor petroleum based oil. If still acting up, clean and re-kit the carburetor. Hope this helps!
Jun 09, 2010 | Husqvarna Chainsaw Piston Kit for 61...
Husqvarna 130BT leaf blower - locked-up
If you stored it with fuel in it, the piston and cylinder may be stuck together. The old fuel turns to a gummy varnish. spray some WD-40 in to the cylinder through the spark plug hole and rock the flywheel back and forth to break it loose. Then flush the fuel system and carburetor. If that isn't the problem, remove the muffler and inspect the piston, rings, and cylinder for vertical scoring, if scoring is present a top end rebuild may be necessary.
Apr 13, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Hard starting and when warms up rpm's drop
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. If so You may need a top end rebuild.
Dec 21, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
46 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
