Question about Gateway 7210GX Notebook
Laptop will not respond to password
After installing some software it required a restart
When  restart was initiated it asked for password and failed to recognize what I remember as the      password. The laptop is unuseable in its present state.
Well if it is a xp try hitting f8 when it turns on then go to safe mode it should open up then go to control panel > user accounts and change the password or just remove it compeletely
Posted on Feb 07, 2008
  • 1,006 Answers
Witch password sir???
Bios password???
Admin Password???
Posted on Oct 26, 2007
Can i unlocked my dell laptop ?
Needed - Model number, and description of exactly what you mean by 'unlocking' - that is, what screen you are on that you are trying to get past. Dell laptops can be 'locked' at many levels, depending on the model and vintage of the machine. I have one Dell that has passwords on the Bios, on the initial bootup screen, on a followup screen to the initial bootup screen for a hard disk lock, and then of course the Operating System. You could also have encryption software installed that would be another place to 'lock' the laptop. Each of these different screens could require a different answer to your question. Without any information in your inquiry, there is no way to respond adequately.
Jan 05, 2015 | Computers & Internet
HI senior citizen with limited computer skills, Have blue screen telling me I have been closed down because unmountable boot volume to prevent damage to pc but I am unable to carry out the instructions...
Possible causes:
1.The file system is damaged and cannot be mounted.
2.You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
3.The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
Solutions:
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
May 14, 2011 | Compaq Armada M700 Notebook
When I plug my 1TB WD external hardrive into my laptop the light with the lock on it lights up and my laptop doesn't respond to it at all.
It says it is password protected...
U need to unlock the HDD from the computer which was installed initially...
U need to unlock the drive with the help of the password that is used in the software supplied along with it....
Dec 08, 2010 | Western Digital My Book Essential 1TB...
How to format acer aspire 4720z
If you have the installation or restore CD insert that in the CD drive and restart the computer. That should stop the problem. For some reason Vista systems like to default to asking for an Administrator password when you enter the recovery for systems. This is not normally the same password you use everyday. It is a password you typed in when you installed the system to begin with. The problem is most people have the store they buy the PC at do the initial install so they don't know what it is. You can try contacting the store that did this install or Acer to see if they have an idea of what it is. It maybe a combination of initials or your last name depending on what the store policy is.
Jun 28, 2010 | Acer Aspire 4720 Notebook
Our Hp zd8000 starts up, gets the password, some of the icons show up, then the screen gets blue with some other colors in bars a message comes up saying could not recover from a hardware deadlock, using...
Try restarting into safe mode and using another computer (if one is available) to download Display Drivers for your laptop. These drivers should be available from the HP website free of charge. Copy these drivers to the CD or floppy (depending on which your laptop uses) and if you could boot up in safe mode, install the new drivers and restart the computer. To restart your computer in safe mode, the computer should say a F key (F1-F12) to press during the post to enter safe mode, or you could hold the power button down while windows is first booting to interrupt the boot, and the next time you power on the computer it should ask you if you want to start up in safe mode 'because Windows could not start normally'. If this does not work please respond again! Thank you.
Dec 02, 2009 | HP Computers & Internet
I have a 5515 Acer Laptop. It was working Great. I installed an AT&T sim usb for internet. It said it was installed successfully and to restart the Laptop. I restarted laptop and now the keyboard is...
theres a couple of options.
1:) you could try using an external USB keyboard.
2:) you could try inserting a system restore CD, into the CD/DVD drive. when prompted use the repair console, or roll-back to a previous installation.
3:) obtain a replacement hard-drive, setup windows. to get the system up and running, then connect your original hard-drive, via an external adaptor. and copy any required files. From external to new drive. Finally. If you can access the laptops CMOS Battery. remove it, and clear the settings to thier default Values.
Mike @ Compurepair.
Dec 01, 2009 | Acer Computers & Internet
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Installation no longer allowed.
updation some times failed
download fresh copy in net ,
remove olser version then install new version.
ur's kishore chowdary
Apr 04, 2008 | IBM ViaVoice Standard Millennium Edition 1...
Software installation
From my experience at working for a projector manufacturer who also dealed with software there is a few things you can do: 1) Open the CD to view the files in there. Contact the manufacturer to make sure all the files are listed on the software that was supplied or that its not corrupted. If that fails.. 2) Ask for them to send you another one if its still not working. It shouldnt cost you anything if its under the manufacturers warranty. After all, how else are you going to use this? 3) Make sure you are following the prompts. If all else fails, restart your computer to make sure that isnt what needs to be done before it works properly. Most software does require your system to be restarted in order to take affect... 3) If that STILL doesnt do it...then verify with the manufacturer their system requirements. Make sure your computer programs are compatible with their software install. If not, they might have an online option for your or a few other options you can do in order to install it. Good luck with your problems. I hope my experience helps you out. Have a wonderful day and keep me posted! Cheers, Cammykins.
Sep 07, 2007 | Canon PowerShot SD1000 Digital Camera
Gateway 7210GX Notebook Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
