Question about LG Cell Phones
Bluetooth lg-p769 with le pan tablet
Try pair Bluetooth with le pan tablet
SOURCE: pairing
I'm having the same problem with my verizon vx8600 phone. Only with a jabra bt350 (listed as compatible). It actually doesn't find anything at all, no phones, no headsets, no bluetooth enabled PC's. Not really sure what to do since I've discovered handsfree talking, I never want to go back
Posted on Jul 26, 2008
Phone Squad
  • 31 Answers
SOURCE: Bluetooth pairing code
The default pairing code for most bluetooth devices is 0000.
Try this to see if it works.
Thanks for using Fixya
Posted on Dec 14, 2008
SOURCE: LG VU does not recognize my blue tooth while trying to pair two
I have somewhat of a solution. when you go to www.att.com/BluetoothWizard, it will prompt you to put in the handset Make & Model and then proceed with the Make/Model of your Bluetooth. It is possible that your Bluetooth headset may not be compatible with the LG Vu.
Posted on Feb 12, 2009
SOURCE: LG Secret
hey! i also had the same problem. i could only send files through bluetooth but couldn't receive them but recently i found out it's becuase my handset common memory was full. so if you delete some files u have on ur handset memory..u may be able to receive files again. this worked for me but im not sure if you have the same problem as i did. i thought that the files received on bluetooth would go to my mircoSD memory chip thingy but apparently it didnt. SOOOO if ur able to send files through bluetooth it should mean that the bluetooth connection itself isn't the problem....i think. it's just ur handset common memory that is full. u can go check the memory space by going to Setting ->Memory manager ->Hanset common memory.  Hopefully this helps!
Posted on May 12, 2009
SOURCE: difficulty pairing bluetooth to lg rumor phone
I had this problem with my LG Shine. I took the battery out, put it back in, and turned it back on. It worked!
Posted on Oct 22, 2009
How to pair lg Bluetooth headset with ipadair?
on your iPad go to setting-> then down to bluetooth. on your headed set Press and hold the multi-function button for 10 seconds until the indicator light turns blue. It is now in pairing mode. it should show up on your iPad, click on your headset and it should pair.
Nov 26, 2015 | Apple iPad Air
My asus memo pad 7 wont send, receive or pair with devices through Bluetooth
hai there, as i analyze, you have to pair manually to other device, cannot straight send file to the others by bluetooth.
before send file and other thing, first make sure some one or other device you want to send have to be recognized by your device by pairing manually.
you have to go to bluetooth setting, for pairing manually you can choose by search or by listening device, don't forget the other device must do the same. after your device completed pairing to the others you can transfer all files you want.
cheers. hope its helps
Nov 07, 2015 | ASUS 8GB ME170C MeMO Pad 7" Wi-Fi Tablet...
Need help with key board
If you are using a bluetooth keyboard, you shoud turn it on, turn your tables, go to setting, enable bluetooth and get it pair with keyboard.
If any other question, be specifi about help you need
Watch video hor to pair tsblet with keyboard
Bluetooth Keyboard Pairing Windows 8 Samsung Series 7 Slate Tablet
May 02, 2015 | EEEKit Portable Office 4-in-1 Kit for 8...
How to pair bluetooth keyboard
On the tablet, Setting/Bluetooth, turn Bluetooth OFF.
On the Keyboard, switch on.
On the tablet turn Bluetooth ON.
You should see the tablet searching and when found click on the device and click PAIR.
Aug 14, 2014 | Dell Venue 8 Pro 64 GB 8" Wi-Fi Black...
Pin for a sumaclife wireless bluetooth keyboard
You enter any four digit pin on the tablet and when it attempts to pair with the keyboard, enter the same pin with the keyboard and press 'enter'. You'll be typing blind so it would be relatively easy to make a mistake and have to try again. My recent experience with the keyboard shows it to be a bit sensitive (or perhaps I'm too heavy-handed for a mini).
I know it's been a month, but I just purchased the same tablet and keyboard today and found this solution only moments ago. I do hope you still have it. Even as a paperweight. :)
Jun 27, 2012 | Computers & Internet
Archos 101 will not pair with menotek bluetooth KB
Unfortunately with Android products, bluetooth pairing either works or it doesn't. If your particular product isn't pairing correctly, it may get fixed in the future with an Archos firmware update, but at present you'll want to try a different brand of keyboard.
Jan 06, 2011 | Archos 101 Internet Tablet 16GB 10.1"...
How to connect to bluetooth (ant) device with lg rumor phone
Not sure if you have paired your bluetooth with your phone yet. Hold your bluetooth button down untell it flashes (usualy blue and red) continuously your phone should then find your bluetooth then it will ask for a code. Usualy the code is 0000. If not make sure your bluetooth is turned on:)
Oct 25, 2009 | LG RUMOR Cellular Phone
Dec 14, 2008 | LG Shine CU720 Cellular Phone
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
Mar 31, 2008 | OEM Systems Bluetooth Headsets - Model...
Cell Phones Logo
18 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
