Question about Dishwashers
Trying to access control panel of Kenmore QuietGuard Standard Dishwasher
  • 1073 Answers
SOURCE: dishwasher panel has no power
on some of these there is a fuse it is located on the side of the control board it is a thermal fuse not resetable if it is blown it has to be replaced
Posted on Apr 25, 2008
  • 11 Answers
SOURCE: Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
Posted on Feb 05, 2009
  • 188 Answers
SOURCE: control panel access
Open the door and remove the top screws connected to the console. Close the door and flip the console down toward you. Remove the control cover to gain access to the control board and the thermal fuse.
Posted on Mar 06, 2009
plnolte
  • 62 Answers
SOURCE: Will not drain
There maybe something stuck in the pump or the pump is bad. I have also seen obstuctions in the drain hoses comming from the pump causing it not to drain properly.
Posted on May 12, 2009
  • 58 Answers
SOURCE: kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Posted on Jun 25, 2009
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
I need an instruction manual for a new Kenmore Dishwasher
go to kenmore web address its there.adrian,,,,
Jul 13, 2010 | Kenmore Dishwashers
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Hello, i have a Kenmore Quietguard standard dishwasher. it is in the "lock" position under dry options and the dishwasher will not start. can you tell me how i might be able to re-start this?
On our Kenmore Quietguard the lock light is at the Air Dry button. Holding the Air Dry button for about 8 seconds turns the lock light off if it is on and on if it is off.
Jan 04, 2010 | Kenmore Dishwashers
Dishes are not clean
HI, there are three different reasons why this will occur in this type of unit. inspect these areas carefully.
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2.Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher. Make sure the temp is proper.
Jul 19, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Kenmore quietguard standard wont start.
Jun 25, 2009 | Dishwashers
check the water inlet valve first
May 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwasher panel has no power
Apr 25, 2008 | Dishwashers
Dishwashers Logo
20 people viewed this question
Top Dishwashers Experts
