Question about Schwinn 250 Recumbent Bike
Schwinn 250 resistance - Schwinn 250 Recumbent Bike
I've had a Schwinn 270 recumbent bike for 4 years. The resistance is completely gone. Suggestions?
I suggest you check the troubleshooting guide in the manual, as there are several causes for the resistance not changing. http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.270-MY17.AM-OM-W.EN.pdf I would suspect that no resistance at all might have to do with a failure of the servo motor, which appears to control resistance through interaction with magnets on the wheel.
Secondly, you can try contacting Schwinn Fitness: Customer Service
If you still can't figure out the problem you may need in-person help. Find a place that sells Schwinn exercise bikes or see if someone at a local gym that has recumbents can help you. The bike is apparently made by Nautilus.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Dec 06, 2017 | Schwinn Cycling
Does the schwinn recumbent 270 bike have a battery? It has an AC adaptor. The resistance will not increase when i press the higher resistance button.
It does not have a battery. Your resistance motor is most likely faulty. The only thing is, with schwinn, you will most likely have to replace the resistance motor, the console, and the wiring. All of this is very hard to find and will probably be more of a hassle than it's worth.
Jun 10, 2017 | Schwinn Exercise & Fitness
Where can I get a schwinn mdl 205p recumbent bike resistance belt?
Is there a belt or a chain? You can look up parts by doing a web search " Schwinn 205p parts.
Jun 05, 2014 | Schwinn Cycling
My schwinn 460 elliptical resistance cannot be changed
see the following details. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced
Dec 04, 2012 | Schwinn 460 Variable Stride Elliptical...
My schwinn 240 recumbent bike shows E-3 on console. the magnet is stuck to the flywheel and won't come off. i've tried adjusting the resistance on the console, unplugged the brake sensor cable, etc. how...
Hello, do you have a manual or electric resistance control? The manual one has a return spring, the electric on has a resistance motor that could be bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Feb 05, 2011 | Schwinn Exercise & Fitness
Cannot adjust the tension on Schwinn 202. Computer is on but tension will not move up or down
I have the same problem with a schwinn 202 that someone gave to me because the resistance adjustment no longer worked. They were advised by Schwinn that the motor needed replacement, but after testing mine, the problem seems to be a lack of power from the computer to the motor. Schwinn tech support will get a call from me tomorrow.
Nov 21, 2010 | Schwinn Cycling
Schwinn 250 Recumbent Bike Logo
67 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
