Question about Food Mixers
Nella sp200a mixer
Both sensors provide a reading when tricked to allow the unit to be used but i bought it at an auction and the return wire from the gate switch is loose where does it connect to?
2 Suggested Answers
  • 81 Answers
SOURCE: NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I have a wiring diagram for the standard A-200. If you send me your e-mail to me I will send it to you. capt_rick1912@yahoo.com
Posted on May 31, 2008
Trying to obtain help on a warrantee product that is defective
Try returning it to where you bought it. They might exchange it for you.
Jul 28, 2017 | Food Mixers
Switch held unit works, release switch unit doen't work
Since you did not provide the exact model number for your unit I cannot give you much precise detailed assistance. However most Hobart mixers are fitted with a standard power switch and you should not have to hold it in position for the unit to work. The switch on your unit likely just needs to be replaced with a new one.
Here is the link to the Hobart Support website and their MIXER page:
http://www.hobartcorp.com/products/food-prep/mixers/
Here is a link to an example of an operating manual for a Hobart N50 Mixer:
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/F7533.pdf
And here is a short video of a 20 Quart Hobart mixer in operation:
http://www.youtube.com/watch?v=MnH1eLtymvQ
And here is a short video of a 30 Quart SP30P in operation:
http://www.youtube.com/watch?v=gfiNYjInCqE&feature=related
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, the follow the onscreen instructions to install the software on your computer.
Please comment back here to this page if you have any details to add (like the exact model number of your mixer), have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Apr 29, 2011 | Hobart Food Mixers
My cuisinart 5.5 stand mixer when you press the on button it starts for a second then it stops.
Make sure the plug is securely plugged into the wall.
Next, remove and reattach any mixing arms etc that may be attached to the mixer. Having one not attached properly can result in a start, start.
If problem persistes make sure the speed is reset.
If problem continues, here is an excerpt from the user manual found here.
http://www.cuisinart.com/share/pdf/manuals/sm-55.pdf
Problem: Your stand mixer has an
overload protection device and if
overloaded, it will shut down to protect
the motor.
Solution: In the unlikely even that this
happens:
• Turn off and unplug the unit.
• Reduce the load by removing some of
the ingredients, and allow the mixer to
stand for a few minutes.
Plug in and reset the speed. If the
stand mixer does not start when you
press the on button, allow the unit to
stand for additional time.
If you are still having trouble, the product comes with a 3 year limited warranty, so if you're bought it within the last 3 years it may be covered.
Good Luck!
Mar 01, 2011 | Cuisinart SM-55 Stand Mixer
Mixer walked off the counter and bent the shell housing... Mixer works but is squeeking and has loose nuts inside...How do i open it up?
Customer Service Information
Before Calling for Assistance
Please read before calling:
• The mixer may warm up during
use. Under heavy loads with
extended mixing time periods, the
top of the unit may feel warm to
the touch. This is normal.
• The mixer may emit an odor,
especially when new. This is
common with electric motors.
• If the flat beater hits the bowl,
stop the mixer. See page 10 for
more information.
If your mixer should
malfunction or fail to operate,
please check the following:
• Is the mixer plugged in?
• Is the fuse in the circuit to the
mixer in working order? If you
have a circuit breaker box, be
sure the circuit is closed.
• Turn the mixer off for 10 to 15
seconds, then turn the mixer
back on.
• If the problem is not due to one of
the items mentioned above, see
Customer Service Information.
• DO NOT return the mixer to the
retailer as they do not provide
service.
If you have a question about your mixer, call our toll-free customer service
number. Before calling, please note the model, type, and series numbers
and fill in that information below. These numbers can be found on the
bottom of your mixer. This information will help us answer your question
much more quickly.
MODEL:___________________ TYPE :___________________ SERIES: __________________
CUSTOMER SERVICE NUMBERS
In the U.S. 1-800-851-8900
In Canada 1-800-267-2826
hamiltonbeach.com
hamiltonbeach.ca
KEEP THESE NUMBERS FOR FUTURE REFERENCE
Sep 17, 2010 | Hamilton Beach 400 Watts 63220 Stand Mixer
Have a A200 Mixer, when turned on, you have to spin it by hand then it runs fine. Whats wrong
The answer is clearly in the starting circuit which doesn't have too many parts, but depends on the type of starting circuit your mixer uses (electronic or mechanical start switch). I'm assuming your mixer isn't very old, as the old units used brushed motors which did not have starting circuits.
The parts of the starting circuit are the motor start winding, the start capacitor and the start switch (probably electronic in your case which is a small silver box with four wire terminals on it). The capacitor should be tested with a multimeter after verifying it's not holding a charge (check with multimeter set to DC Volts, mixer unplugged, should read zero volts).
Start winding should be tested with the meter to measure ohms. Locate the wires leading to the motor (hopefully only three wires) and you should get a reading for all three combinations of measurements (wire 1-to-wire 2, 2-to-3, 1-to-3) if meter indicates open on any of these, motor stator is bad(this is pretty rare and quite expensive).
Electronic start switches are not very simple to test, but if the capacitor and motor test out OK with the meter, and all the wiring is intact (look closely for loose wires, burned wires, poorly crimped terminals, etc.) then it must be the start switch.
May 19, 2010 | Hobart A200 Stand Mixer
Bought Hobart D300-T at auction
i have another for sale - working 1500,00 cdn
Oct 19, 2008 | Hobart D300 Stand Mixer
Hobart L-800 Mixer is rotating in the wrong direction
Take the top cover off.Trace the plug going into the top,there will be 4 wires,leave the green wire alone.Unplug the mixer and any 2 wires reverse them that should do the trick.
Aug 29, 2008 | Food Mixers
Kenwood chef
It could be a broken drive belt, this is usually located under the top cover. You may need to remove a couple of screws to get at it. Don't forget to unplug the mixer before trying this.
Mar 18, 2008 | Food Mixers
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
