Question about Pioneer AVH-P4000DVD Monitor
My ipod will not sync with my avh-p000dvd
I cant not get my ipod to work with my deck
Hi y kid by mistake pressed the reset buttton on my avh p6600dvd and now the deck powers on but i cant set the volume or skip etc.please advise
yo dude i got d same 1 earlier n the problem i got ws d same 1 .issue ws the main supply chip got corrupted n it cn not b repaired so sell it if u want.contact me if u wnt to sell it .............at abhinavsood98@gmail.com
May 03, 2011 | Pioneer AVH-P6600DVD Car DVD Player
Ipod touch wound sync to my computer. i had a nano first. when i tryed to sync my ipod touch i did not reg. to my computer, i just tryed to copy my music to the new ipod. my daughter shares our music from...
Open iTunes (without iPod connected). Create a new playlist and copy songs you want on your iPod into that list. Next connect your iPod. Once iTunes recognizes your iPod then go to the music tab and click on 'sync playlist only' and chose the new playlist that you created. Click sync. Only the songs in your new playlist should be copied to your iPod.
Dec 30, 2009 | Apple iPod touch
I cant play ipod video thru pioneer avh p 3100
Select the Source menu, press the OFF key, touch the screen and select AV MENU, and select initial, then touch AV input 1 until it says I-Pod.
Nov 05, 2009 | Pioneer Car Audio & Video
Ipod problems on my pioneer avh
To be working the ipod need to be hook up with the cable cd-1200 (not sold with the avh)and to be plug to the ipod plug on the back of the radio..if you plug the ipod on the usb it wont do..the cable is around 30 $ ..it is the good way to play your ipod ..but if you have a ipod touch 2 generation like i have it wont charge ..if you have any other ipod it will be charging when in use..
Mar 04, 2009 | Pioneer AVH-P4000DVD Monitor
Cant download songs
Plug the ipod into itunes, add music to you itunes playlist, then click the "sync" button on the Ipod device tab.
Basically where your ipod is click sync after you add the music you want to your itunes playlist.
Jan 05, 2009 | Apple iPod nano
Prob on ipod nano
try resetting ipod?
Jun 27, 2008 | Apple iPod nano
Ipod will not play video to my head unit AVH P5900DVD
ok for the first post with the ipod not showing video .. make sure that you have the correct cable running from behind the deck to the ipod .. (iPod Direct Control (CD-I200 Required) once you have that connected you need to go to the video settings of your ipod and turn on the video out .. by default its offf... also remember with movies on your ipod .. that has to be manually selected from the ipod itself .. you cant control the videos from the pioneer unit.. only the audio/music on your ipod can be selected from the pioneer unit..
May 24, 2008 | Car Audio & Video
IPod 3rd G Nano syncing problem
maybe holding resetting the ipod might help by holding the middle and menu key???
Apr 21, 2008 | Apple iPod nano
Video ipod
you have to get an iPod cable that gives you RCA outputs. Just connect the RCA outputs from the iPod to the AUX inputs on the unit. I believe that should do it. Ebay sells the iPod cables, and most electronics stores should as well
Dec 22, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Ipod input
hi,put the yellow wire of the ipod adapter to the yellow power cable and the black to an car body earth,then plug in the black cable,hey presto!!
Feb 03, 2007 | Pioneer AVH-P5700DVD Car DVD Player
Pioneer AVH-P4000DVD Monitor Logo
16 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
