V800 manual for eco sound blue tooth speaker - Audio Players & Recorders
  • 77 Answers
SOURCE: blue tooth adapter
Connect the headphones to the bluetooth.
Open the control panel, go to Sounds and Audio Devices.
Click the Audio tab.
Under Sound Playback (top portion of the tab), it says 'Default Device'. Drop the menu down and select your headphones. Click apply then ok, and you should be good to go.
I can't guarantee that this will stay set up this way. If you disconnect the headphones, you very well may have to run through this again.
Posted on May 06, 2008
koolmind
  • 75 Answers
SOURCE: now sound from speaker
your mobile's sound ic is damaged or burnt u need to change it...
Dont forget to rate
Posted on Sep 07, 2009
Testimonial: "Good comment."
casouzaj
  • 1118 Answers
SOURCE: Unable to use new h500 headset
The H500 is a monaural headset, thus good for phone calls only, not for listening to stereo music. You haven't specified which Motorola phone you own. Check in its user guide if it is able to handle stereo bluetooth headsets (i.e. if it bears the A2DP and AVRCP bluetooth profiles), which are suitable for music streams. If your phone is able to handle them, go to the mall (or store, or even online), buy one set which suits you better, pair them with your phone and enjoy!
Just my 2 cents... Carlos
Posted on May 23, 2010
  • 10 Answers
SOURCE: Can I hook a blue Tooth speaker to my model #ld320ss8
I do not believe your model of TV has bluetooth support.
You will have to connect it with an auxiliary cable, or use other speakers with the appropriate cable.
You can use wireless speakers, but they would come with a receive that would have to be connect to the TV with a cable.
Posted on Dec 18, 2014
Terry Corrow
  • 10875 Answers
SOURCE: what is the pairing code when trying to blue tooth a Modal Blue tooth speaker? the model is MD-SPBT01
http://images-usweb.bbystatic.com/modal/files/MD-SPBT01_Blue-Tooth-Speaker_Quick-Setup-Guide_English.pdf
25568178-luwwge4czbaizljvp4ehh2hd-2-2.png there is no code,choose the device
unless the device needs a code,then it will show one
Posted on Mar 14, 2015
Bluetooth headset shows CONNECTED but the audio still comes thru thetablet's speakers.
There mabe a setting in sound somewhere to use the bluetooth instead of the tablet speaker. Search for an instruction manual on the model number and see if it has a external sound setting .
My laptop does the same thing . ! and I had to change a setting to get it to send sound to a blue tooth speakert
Jan 16, 2017 | Radio Communications
USING SOUND BAR FOR BLOWN SPEAKER ON TV
If you use Blue Tooth, wires are not needed.
Press the manual Mode button to find blue tooth mode. Green light will display. Blue Tooth is a general signal sent out. There is no specific setting for TV.
If your TV is sending out a Blue Tooth signal, it should find the speaker automatically. http://www.ematic.us/sites/default/files/ESB212_Manual_01_0.pdf
Check your TV's Blue Tooth settings and have it scan. Default password/code for the sound bar is 0000.
Also check your remote batteries. Sometimes they are installed backwards by the factory so they won't go dead.
Mar 22, 2016 | Ematic ESB212 Wireless SoundBar with...
How do you connect the onn mini speaker model BTS108
Search for the speaker from the device being used to connect!
Oct 15, 2014 | Audio Players & Recorders
Can I connect to Vizio TV with blue tooth
If your ear buds have been connected to any device before your TV then it won't work. If you want to connect it to your TV you turn on your headphones, hold the call button for 3 seconds, and you will see ur light flash and connect it to your TV. If this didn't help then go to the manual and check how to connect your headphones to your TV.
May 24, 2014 | AUVIO Bluetooth Headphones
No sound from speakers, loose connection in green jack wire.
Yeah man I have the same problem!
I guess I will just buy a new jack!
May 27, 2009 | Logitech Z-640 5.1 6-Piece Home Theater...
Config Problems After Repair
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Nov 02, 2008 | Yamaha RX-V800 Receiver
Blue tooth adapter
Apr 27, 2008 | Computers & Internet
Yamaha RX-V800 Zone 2 Operation
yes it works great. hook them up to zone B. then below the power button is a A/B button. select button B and then zone B will work.
heres the manual if it helps
Apr 02, 2008 | Yamaha RX-V800 Receiver
26 people viewed this question
 Grubhead
Grubhead
